Aeroforce Gauges for your Ecoboost vehicle
Started by EcoPowerParts, February 19, 2014, 01:37:02 PM
Quote from: SHOdded on February 19, 2014, 06:28:56 PM
So really what we would need is something that provides a HAL like Windows does, bypassing confusion for the PCM's OBD from multiple requestors.  It would introduce cost, complexity, and slight delays in data display though.
What do you mean by Slight ?  Yeh , money could be an issue to me  but it might be worth it .
Quote from: SwampRat on February 19, 2014, 06:32:01 PM
What do you mean by Slight ?  Yeh , money could be an issue to to me it might be worth it .
It's going to have to be made from scratch and nobody has done one so it's not going to be cheap or even affordable for the first one unless you're an electronics GOD that understands CAN bus data communications and ID. :)
SHO MAN
That guy in the vid said Echo-Boost...just like my Dad. LOL
forcefedjunkie
Quote from: ONLYA6 on February 19, 2014, 02:51:28 PM
Sweet! Will be purchasing one tonight.
Just to clarify, if you get just 1 gage you can still have 1 line display constant and the second line can be programmed to cycle?
You can have both lines constant, both lines cycling, or just bottom line cycling.
Todd
forcefedjunkie
#19
[/quote]
Let me try to rephrase  this   :   Tuner is UNPLUGED  ..... will the same issues arise with a dongle running Torque and Aeroforce Gauges at the same time ?
IF I buy these Gauges it seems that they must daisy chain ... can you run 3 at once and I would think they would just hook up to the OBD II port via one connection ?
[/quote]
You can run 1,2, or 3 Aeroforce gauges at the same time, they are programmed to run together.  One connection to the OBD2 port, with the cable splitting to both gauges of a dual set.
Todd
SHO MAN
Question: will this gauge read and display trans temp and oil pressure without an added sender? Im unsure if the trans temp and oil pressure is in the obd2 data.
Thank you
jmr061
Ford does have a data coming in for transmission fluid temp. I can check on oil pressure but I can't tell you PID they are
Jason
16 Edge Sport
Ecoboostsho figured out the PID for trans temp.
I can confirm it is working.
Here's the link
http://www.ecoboostperformanceforum.com/index.php?topic=2118.0
Torque Pro    Missing PID's for Transmission Temp Guage .... and others
ONLYA6
Just received mine. I do have 1 complaint - I paid $10 for the additional faceplate that says SHO. It is just a blank faceplate with a cutout sticker on it. I would have expected no less than it printed on there like the factory plate.
Steven
2013 Taurus SHO - Best ET 12.7/ MPH 110
1999 Mustang V6 - Turbo - 474 whp 431 wtq
Quote from: ONLYA6 on February 24, 2014, 03:06:05 PM
I only know what they charge me, I just ordered one for my CTS-V with dual wide band setup (damn V has narrow bands stock)
ONLYA6
I'm not complaining on your part Mike as a vendor. I would think Aeroforce would do better than a sticker on the faceplate.
Steven
futat2
Looks good and hard to tell its a sticker in a photo. How dose it look in person? can you tell right away or do you really have to look at it? Either way it is a nice gage for the price.
2013 SHO PP, Sparkly Black
bone stock (for now)
Got the windows tinted, 15% all around
Kolk1
SHO MAN
Wow!  A sticker? That just killed it for me. I have one of Crash's center gauge pods and was going to get 3 of these with the SHO faceplate, but not if it's just a sticker. I still plan on getting the triple Aeroforce Interceptor setup, but not gonna go with the "custom" SHO sticker. Thanks for pointing that out.
Boggus
Someone needs to sell a one gauge pod, column cover type.  Not a fan of the A pillar.
2013 unleashed SHO PP
