I am still trying to get my head around the boost numbers I am seeing with my Aeroforce gauge.
When I first installed the gauge, I saw a spike of 13.6 but I have NOT been able to duplicate it since. It must have been a fluke or some weird set of circumstances. Last night, I did a couple of WOT runs. In 1st gear, WOT caused the boost to literally jump to 12.1 and it stayed there until the shift when it dropped to about 9. Through most of 2nd gear, it showed 10.6 -10.9 - but no higher. It again dropped at the shift to 3rd. I didn't go to the top of 3rd because I was not in Mexico. Doing some pulls in manual mode 6th gear from about 1500 RPM only showed about 7 PSI.
With my tune, I seem to get more boost in 1st gear than in the higher gears. It also seems to maintain the higher boost all the way to 6200 RPM - at least in 1st and 2nd. Again, I don't know how accurate this is. The car is running great so I am not complaining. Is this behavior consistent with what you guys see with other electronic boost devices?
