En route to Livernois!
Started by ONLYA6, February 15, 2014, 07:15:23 AM
REDSHOCGO
Was a stupid move to do away with the 3.7 liter option the 6 had
2010 Red Candy Sho 402a option non/pp w/unleashed tune,3 bar map, k & N CAI, Corsa catback exhaust, tints 35% front 20% back vta conversion,plastidipped front grill (matteblack), Curva Concept C7 wheels w/20" toyo proxes +4 and Sony Xperia z running torque pro
2011 Sonata 2.0T Limited tinted
2007 Pontiac G6 GTP cpe w/crab intake,Led sequential taillights, custom exhaust(now gone)
Thread sure has been quiet.....
Any updates since 7 days ago?
Any updates from LMS, Steven?  Busting at the seams with curiosity over here!
Livernois Motorsports
The car is inline for tuning, but we had to button up some mechanical items with the car to prep it for the dyno first. She will be on as soon as the dyno frees up though.
ONLYA6
Quote from: Livernois Motorsports on March 11, 2014, 03:05:06 PM
Atleast I'm getting updates from someone!
Steven
2013 Taurus SHO - Best ET 12.7/ MPH 110
1999 Mustang V6 - Turbo - 474 whp 431 wtq
ONLYA6
Well I suppose I'll post up an update.
I had to get a new oxygen sensor put on (thru a code on the drive up, ended up putting both up streams on for consistent reading) and of course get  the 3 bar swapped out when I got there. It had to get rescheduled for tuning at that point. Right before tuning it was realized the meth wasn't working correctly with the signal wire tapped into the factory sensor. The standalone map sensor was installed and that fixed the problem.  It was rescheduled again for tuning.
The car finally got on the dyno April 7th. Currently it is still being tuned. A loose t-bolt caused some delay also trying to figure out why it wasn't making a clean pull. Apparently with upgraded turbos and applying the V8 tune everything needed started from scratch.
I'm going to keep it around 400whp. I talked to Dan and they have seen a few broken rods on cars making 430ish+. Upon teardown it was found to be a rod failure alone and not tune/fuel related. Being that this is my DD I don't feel like replacing the motor. TQ should be very good so I might still end up knocking on 11's door. It sucks being told "with this setup you can make pretty much whatever you want to" but holding it back to a reasonable level. Better safe than sorry!
I'm ready to have this car back. It's coming up on 3 months.
Steven
Sounds like you are really, really close to getting your SHO back, Steven.  It's going to be a blast to drive!
Needmoreboost
All I can "once again" say is Wow. 3 months...
Are they reimbursing you for a rental by now?  Lol. ;)
I hope it runs good once its done.
2014 Mustang GT/CS: white
navbtcret
Quote from: Needmoreboost on May 07, 2014, 04:24:27 PM
You must be an expert on tuning?
2013 SHO Non PP, LMS 93 Performance v8, 3 Bar MAP, 170 Stat, MDesign CAI, Hot Pipes with TiAL BOV, PPE Catted Downpipes
Needmoreboost
Quote from: navbtcret on May 07, 2014, 04:36:04 PM
No, I just cant figure out there customer mgt strategy.  Is it LIFO or FIFO.  Maybe Dave Ewing knows...?
Quote from: Needmoreboost on May 07, 2014, 05:08:46 PM
Dave is no longer on this forum as i understand it..
LIFO  ......   FIFO    ?
Queueing/Accounting terminology:  LastInFirstOut, FirstInFirstOut
Fifo ever so popular in grocery markets.  I always Check dates and grab milk from the very back of the shelf.
black99lightning
Sometimes these threads have GIGO
2013 Esport 13.44 @ 103.6
1999 Lightning 12.44 @ 108.4
2012 GT500 10.96 @ 130.6
2006 GTO 12.83 @ 107.8
2013 CTSV coupe 11.79 @ 119.7
