Dyno Results
Started by SHOdded, February 13, 2014, 03:20:22 AM
Darreli's Dyno Sheet
12-13-2012, 12:55 PM
Darrell's 2010 SHO has the following mods:
  • Livernois Motorsports Catted Downpipe
  • Livernois Motorsports Methanol Injection Kit
  • Livernois Motorsports Dyno Tune
  • Corsa Exhaust
  • CAI
The factory turbo housing was modified and it was fitted with a larger billet wheel.
Before numbers were 277 WHP / 371 WTQ after numbers were 435 WHP / 521 WTQ. (If you get rid of the initial spike in the baseline, it made 330 WTQ stock)
Looks at the gains... it's up 190 WHP / 225 WTQ at 6,250 (stock vs all mods)
Here is before turbos and downpipe vs all current mods
Darrell and Mike both have the power to go 11's, they just need to get the power to the ground.
Thanks for looking!
-Rick
bpd1151 Video of my dyno & 12.37 run, compliments of Livernois Motorsports!
11-25-2012, 02:51 PM
Thanks to Mr. Rick LeBlanc of Livernois Motorsports fame, for putting this short video clip of my most recent dyno pull, and 12.37 run down the Milan, MI dragway during their 2nd, 2012 Customer Appreciation Day.  The hospitality, professionalism, and ability to apply their talents in making my 2010 SHO go ever faster is truly much appreciated.  Thanks to all the staff at LMS for another wonderful experience. Enjoy the video folks
http://youtu.be/ohewGN6MVwU
Ed:  1:06 mark - Dyno graph
Scrming Dyno with Livernois tune +/- Methanol
06-08-2012, 12:02 PM
Ok... realize this is a Flex EcoBoost... But this should give you an idea of the gains you can realize with a tune...
BLUE - Stock Tune
RED - Livernois Stage 4+ Tune
GREEN - Livernois Stage 4+ plus Methanol Tune
The low end torque improvement is simply STUNNING!!!
For the V fanatics at heart ;)
LMS Black Diamond Caddy V Coupe... Head/Cam Build w/ Photos and Dyno Sheet
02-28-2012, 11:06 AM
We recently did a build for a customer with an 700 mile auto trans Black Diamond Coupe.
In stock form, it made 438 RWHP / 431 RWTQ. After the following mods, it made 661 RWHP / 605 RWTQ.
Mods are:
Livernois Motorsports CNC LSA Cylinder Heads / Livernois Motorsports Stage 2C High Lift Camshaft / Livernois Motorsports Pro-Series Heat Exchanger / Livernois Motorsports 2.55" Supercharger Pulley / Livernois Motorsports Double Bearing Idler Pulley / Livernois Motorsports Hardened Pushrods / Innovators West 9.1" Oversize Balancer / Oversize Crank Pulley Ring / Kooks Stainless Longtube Headers / Kooks Stainless Connection Pipe w/ Cats / Solid Supercharger Coupler / Airaid Cold Air Intake / 60# Injectors / NGK TR6 Spark Plugs / 160 Degree Thermostat / GM Supercharger Discharge to Intercooler Gasket / Billet 10.5" Stall Converter / ARP Head Studs / GM Head Gaskets / GM Exhaust Gaskets / NGK Spark Plugs / Eibach Springs / Mickey Thompson 305/35/19 Drag Radials / Livernois Motorsports Dyno Tune / Tint... So dark it looks sprayed on, including windshield
2012 Black Diamond Head/Cam CTS-V Coupe - 661 RWHP!
Ed:  1:15 mark - Dyno graph
Regards,
Rick LeBlanc
First-SHO Dyno results 6/12/13
06-13-2013, 02:50 PM
Nice improvement!
FASTEST 2011 Ford Taurus SHO on record @ 12.0909 115 mph
Silver/Black LOADED / Ford Lockpick / Forgestar F14"s 20x9.5 with Nitto Invo's / Wilwood Front Big Brake Kit from TCE
Airaid CAI / Corsa Cat back / Livernois Down Pipes / Livernois Tune's / H&R Springs with camber bolts.
Torrie - 170 F Thermo & Radiator / L&M Airflow Throttle Body "Only one made and I have it" / Alkycontrol Meth Injection
Upgraded Turbo's / 2013 Trans and Oil Cooler / LED's on always
06-13-2013, 06:33 PM
OK OK, boost is around 20-22 psi I will tell you this program will not be for a stock suspension as the numbers power up very quick for the track.
My car has gotten better MPG with a program. All of them as more torque moves the vehicle quicker.
The throttle body is a one only make and I really do not know what gain it makes as the numbers are close to other cars, but throttle response is improved with it.
gregoire Dyno chart from Livernois visit
2013 PP Downpipes, exhaust, CAI, Springs, 170 degree thermo and tune.
OnlyA6 Dyno Results - 2013 SHO - 397 WHP
04-20-2013, 05:23 PM
397 AWHP / 381 AWTQ
2013 Taurus SHO / Performance Package / Livernois Motorsports 93 Tune / NGK 1 step colder plugs
170* Thermostat / AIRAID Intake / Corsa Exhaust
4th Gear pulls, SAE corrected on a Dynocom Dyno
Dyno sheet shows the 1st and 3rd pull. 1st pull engine was still fairly cold. The HP seemed high - I was expecting somewhere around 350. For comparison, right after me a 2011 Camaro SS L99 Auto w/ intake made 333 WHP / 346 WTQ, which is right on for that car. So who knows...
Scrming MRT catback installed on Flex
07-21-2012, 08:06 PM
Not sure if the SHO uses the same mufflers as the Flex.. but we cut open the stock mufflers from our Flex and found them very restrictive.
Now, unfortunately we didn't do a true before and after dyno session... but we did compare my Flex with the new exhaust against Livernois stock baseline dyno... so not an ideal situation, but i think it does confirm there is some HP to be freed up in the exhaust:
RED = Stock Base Line
BLUE = MRT axle back
HP (fig 1), Torque (fig 2)
twnscrw13 Whoop.. new mods. :)
http://www.ecoboostperformanceforum.com/index.php?topic=1261.msg13874#msg13874
2013 PP SHO. LMS 4+ tune, catted down pipes, Corsa Exhaust, AirRaid CAI, truck plugs, 170 thermostat
Courier6 Re: Whoop.. new mods. :)
http://www.ecoboostperformanceforum.com/index.php?topic=1261.msg13936#msg13936
2013 PP SHO.  LMS tune, PPE downpipes, Corsa catback, Air Raid CAI, 170 deg thermostat
0:23 mark – Dyno graph
4DRHTRD First Ecoboost to hit 600WHP!
http://www.ecoboostperformanceforum.com/index.php?topic=1172.msg12675#msg12675
http://www.ecoboostperformanceforum.com/index.php?topic=1172.msg12711#msg12711
0:37 mark – Dyno graph
2011 Ford Flex Tuxedo Black Titanium EB
Megan Coilovers, Custom fuel system, E85, custom cutout
Shoman04 LMS Tuned with Meth
See the video at:  https://www.youtube.com/watch?v=hCIWVhlcYQk
See the dyno graph at:  https://www.youtube.com/watch?v=pU8rfm6OHbQ
2011 SHO, Livernois Tune Stage 5, Airaid CAI, Dynomax Mufflers, LMS down-pipe, Magnaflow X-pipe, Custom 2.5"exhaust pipe
