Quote from: Spartn27 on February 11, 2014, 06:53:02 PM
How would I go about using a multi-tester to test if the wires are intact? I do know that if the EPAS senses any sort of resistance in turning the wheel it will throw the code to prevent damage to the electric motor.
What has got me is that there are 3 codes conceding the EPAS, FAULT being an electrical fault and the latter 2 being component failure.
This occurred after I blew a strut and restarted the car, which is when the code came on in the info display center and when I lost all power steering. I have no way of knowing what code it is exactly as the OBDII scanner won't read any faults. I'm going to try and find a buddy or someone who does have the Ford scan tool to try and get a code.
OK.. understand your situation... My bad.
Getting a code read as you suggest is a good start.
Getting the EPAS wiring diagram may be a necessity for you to check the connections and electrical continuity yourself. How else will you find them?
To check continuity apply a multitester to both ends of the wire and send tone (electricity)... if it reads a voltage then it's intact.
Lastly.... sometimes just disconnecting the connectors, cleaning them and reconnecting will fix it if oxidation is the cause.
Sounds like the incident damaging the strut may be at the root of the problem regardless of cause, sounds hard enough to be mechanical or electrical and both should be checked.
As far as a new diagnostic charge... you decide how much your time is worth. However, the dealer could be asked to check all the connections as part of the new (or in addition with the old) diagnostic report with either dealer you use. There is apparently some chance that the steering box is OK.
