Quote from: Larrylu on February 02, 2014, 06:33:18 PM
Anybody know what torque is called for in tightening the plugs?
I wasn't aware of Ford's tq spec. at the time, which is why I didn't list any specifics in the OP.
I torqued to 11 ft.lbs, because that's the spec. I've used for years in my previous engines w/ aluminum heads.
At 10 to 12 lbs, your snug enough, without having to worry about stripping out threads, IMO.
If somebody can source the actual specification, I can add it to the OP.
This job too me about 45 minutes, including prepping the plugs. And I was lolly gaging around here and there too. If you really can get in there and do it without displacing the valve cover vent and the piping, I could definitely see it done in 20 or 30 minutes.
I'm the type of guy who'll go out of the way a tad to make the job less stressful. Confined workspace is aggravating for me. I get worked up alot, wrenching on automobiles. Haha! XD
By the way, I'm welcoming of additional, helpful information. If I left something out, or if you've found a way to simplify the process, by all means, share it! It won't offend me any.
