BOV to VTA
Started by 2010SHOtime, January 27, 2014, 10:46:27 AM
Quote from: Airbornemaikai on September 19, 2014, 08:28:09 PM
I bought some cobalt vice grips specifically for this, damn things aren't even a year old but wont remain clamped
Lowes will take back damn near anything if its their brand.
I have a mini screwdriver that I use everyday, I must have exchanged it 10 times already.
A while ago when i did it had pretty good luck with a small stuby flat head screw driver,while holding the hose at the same time would insert the flat head in the gap of the clamp and push it back,at the same time would twist and pull the hose off gently&slowly remove the hose cause the BOV is fragile,worked for me.cause originally the clamp was facing against the firewall for some reason so you dont remove it i guess from the factory.
2Canches
http://youtu.be/UOUQ7eqIgIY 💥
Sent from my 📱 non ➕ using Tapatalk in 🇨🇦
polskifacet
This absolutely doesn't work on a 2013 SHO. The bovs bleed out all the pressure during acceleration for some reason so you can't build boost. SIGH. Would have been sweet if it did work.
Wilson
Someone lied to you brother :)
Wilson
2013 SHO (non-PP) Ruby Red Tintcoat
Leading Edge Tuning 93 Tune | 3 Bar MAP | 170* Thermostat | Airaid Intake | PPE 2.5" Downpipes | Snow Stage 2 Meth Kit | H&R Lowering Springs | 22" Falken RT-7M wheels | 265/35/22 Falken Ziex TZ05 tires
polskifacet
Sorry dudes, thanks for the quick response. I forgot to connect the little vacuum tube since I removed the whole intake pipe to get to the rear bov.
southtxSHO
Do I have to do both sides to VTA ? Or will one side do ?
2011 SHO non PP
LMS 4 +tune
LMS Cai
LMS catted downpipes
12.89@ 105 MPH best time @ Edinburg Raceway
One side will do, but it won't be as loud. I had just the front one vta and I could barely hear it.
southtxSHO
Quote from: glock-coma on May 16, 2015, 08:58:58 PM
Ok thanks ... will do it later , lent my toolbox to bother -in -law
2011 SHO non PP
LMS 4 +tune
LMS Cai
Boggus
I wonder if you installed a cap on the bov with a smaller opening would it change the sound?
2013 unleashed SHO PP
Quote from: Boggus on August 20, 2015, 04:58:58 PM
I've seen videos with people putting duck calls on the BOV. It's pretty funny
Quote from: glock-coma on August 20, 2015, 05:15:49 PM
Yep... Plays music for the hula dancer bobble head on their dashboards just below the fringe.
