Started by Txstrmhntr, January 24, 2014, 09:24:47 PM
Quote from: shoman04 on January 25, 2014, 12:03:55 PMIf you don't have much time on the track. Here some tips 1) A 1/4 tank or less of gas, 7lb per gal. 2). Stage short ,just start to have the 2nd light on. 3) Launch on the last yellow light. "STAGGING SHORT WHEN LAUNCH ON YELLOW YOU HAVE 6in ROLL BEFORE THE GREEN GO ON". 4). Weight No Spare Tire, No PP Air pump, I have gone so far to take the mats and back seats out(40lb). My best time tune only is 12.669sec 1/4mi @ 59deg!!! HERE is a 2013 5.0 Mustang @ 85 deg I ran 12.74. GOOD LUCK!!!!!!https://www.youtube.com/watch?v=p19-JemCQz0
Quote from: black99lightning on January 25, 2014, 12:15:23 PMSorry but if he can drive you're going to get beat, badly. It's an HCI LS1 so low 12's high elevens at 117-120 through the 1/4. I think it's sad he had to go purchase DR's to run you. Tell him no Dr's or no run, that is your only chance is if he spins.
Quote from: Txstrmhntr on January 25, 2014, 12:20:05 PMQuote from: shoman04 on January 25, 2014, 12:03:55 PMIf you don't have much time on the track. Here some tips 1) A 1/4 tank or less of gas, 7lb per gal. 2). Stage short ,just start to have the 2nd light on. 3) Launch on the last yellow light. "STAGGING SHORT WHEN LAUNCH ON YELLOW YOU HAVE 6in ROLL BEFORE THE GREEN GO ON". 4). Weight No Spare Tire, No PP Air pump, I have gone so far to take the mats and back seats out(40lb). My best time tune only is 12.669sec 1/4mi @ 59deg!!! HERE is a 2013 5.0 Mustang @ 85 deg I ran 12.74. GOOD LUCK!!!!!!https://www.youtube.com/watch?v=p19-JemCQz0Im pretty good at the track, i go at least 2-3 times a month when its open. No spare but I do keep the air pump (to air my tires back up when im done). My bane seems to be the inability to cut decent 60's, ive had a couple 1.7x but normally im in the 1.9x range. I blame the GY F1's, but this is a heavy car to get moving.Quote from: black99lightning on January 25, 2014, 12:15:23 PMSorry but if he can drive you're going to get beat, badly. It's an HCI LS1 so low 12's high elevens at 117-120 through the 1/4. I think it's sad he had to go purchase DR's to run you. Tell him no Dr's or no run, that is your only chance is if he spins.I dont think hes upgraded his heads, looking on his facebook it seems he bent some valves a couple months ago when his timing chain broke and installed the cam then but didnt have the $$$ for the heads so kept the stock heads, If im assuming right the stock heads are really limiting what that cam can give him. Im putting him at a high 12 in the 1/4. I think its going to be close and im hoping ill jump him hard enough on the line he panics and doesnt pedal it, that usually works against inexperienced guys with more power than me, at least it has with Cts-vs and a ZL1 i raced.
Quote from: BiGMaC on January 25, 2014, 03:46:06 PMAhhhh Kennedale..... Lived down by the shooting range there when I went to school in Ft. Worth.... didn't know they had a track. Of course it's been thirty years. It was out in the boonies then.Best of luck in your grudge race!
Quote from: Txstrmhntr on January 26, 2014, 07:38:46 PMHis third pass he broke something in the rear had to be towed off the line.
Quote from: 65460 on January 27, 2014, 06:22:09 AMNice job.Was the guy around to see you run the 8.17?
