Here is a very brief
"How To" as mentioned earlier as my patients isnt what it once was. LOL. Z
BIG to Mike.B over @
www.ecopowerparts.com for the silicone hose which fit like a glove which made the process of installing the
FRONT CAC TO FRONT TURBO HOSE that much easier as compared to the previous version which was a pita.
The overall Silicone hose appears to be made of high quality as compared to the OEM Rubber hose which in overtime can be prone to cracking and lead to hard to find boost leaks especially in higher temp climates.
1.5" To 2" ID hose .
I believe its a 4mm Thickness 3-Ply Nylon for Strong Reinforcement
Withstands Operating Temperatures from -65F to 500F Degrees Fahrenheit Working pressure 80 psi / Burst pressure 245 psi
Inlet / Outlet: 1.5" / 2" based on my research.
FYI -the hose did not come with hose clamps and just used my previous T-bolt clamps which came since purchasing the Hotpipes.
I found Ebay to have the best price on the T-Bolt clamps,link below.
2.25" and 1.75" inch T-bolt clampshttp://www.ebay.com/itm/Mishimoto-Stainless-Steel-T-Bolt-Coupler-Clamp-2-25-MMCLAMP-225-/272678956431?hash=item3f7ceead8f:g:vR0AAOSw7GRZCqZF&vxp=mtrThe procedure is basically very straight forward and took me roughly 30 min for the entire install.
The Hose is located towards the front drivers side underneath the bumper.
If you have a lift you can certainly do it much quicker but in my case used an old set of Rhino ramps .
1)Remove the Under Radiator/Engine-Cover Splash Shield and the front
Engine Splash Shield while removing the retainer nuts.
2)I found using an 8mm socket + 1/4 socket wrench to be ideal for removing the OEM Hose especially for tight spaces.
3)10mm socket and 1/4th socket wrench to install new silicone hose with Heavy Duty T-Bolt clamps using 11ft- Ibs torque.
I also found very minimal amounts of oil on the original hose which leads me to believe the CAC(intercooler) is working efficiently and as designed IMO.
If you have any questions as always please feel free to ask. Z
Previous rubber HoseNew Silicone Hose
