Quote from: BiGMaC on March 07, 2014, 12:13:40 PM
Quote from: Lanson on March 07, 2014, 12:05:07 PM
Quote from: BiGMaC on March 07, 2014, 10:58:03 AM
Lanson... Excellent Work..... I can hardley wait to see you do some for the SHO! I am very impressed!
What would you guys like to see done? I need either a test vehicle for a while, or some really good pics and really good measurements. Then I can create a basic model in 3D, and have someone build a cardboard test example to prove it works. Then it is just a matter of making sawdust.
I'll get you some pics and measurements... Thinking in the trunk..across the area behind the back seat...(I may need my spare!) .. forward firing subs and port forward if ported...fits up on the "shelf" behind the seats with ability to mount amp and/or DSP on the rear of the box for tuning... I don't need to be able to see the subs, but i do need to be able to access the electronics.
Other info you need?... let me know.... and TIA, You're the man!
Sounds great, but definitely REAR-fire. Acoustically, we also want to keep the output of the port and the output of the sub together. That's the main purpose of a ported box, to tune with the sub itself. To use the port only would be the responsibility of a BANDPASS box. Which, btw, we could engineer to perfection as an option.
Front-firing a sealed box creates create response in the mid-bass / bass region, but the sub bass gets lost. Example:
This is a build I did for my brother in-law's Sentra
False wall rear
A full amp and processor rack on a shelf (to allow the spare tire room to get out as needed)
This system was incredibly loud, but could not dig super deep. Testing with a basic RTA and mic found that the front-firing subs were actually cancelling out via the wave that was being created in the trunk and reflecting back to the cabin. Bass waves pass right through most materials, so even though we blocked the trunk off with wood and carpet (and foam seal), it was transparent to bass. The result, a damn loud but not very low-playing system, despite some gorgeous Alumapro subs.
This system (which was made in haste and for temporary use only, so forgive the not-professional amp mount up top) was in my Acura TL, and would play down to the lowest frequencies you could dare a 10" to go. Granted, these are special subs (Acoustic Elegance AV-H10), but point is they were rear-firing, and the bass wave was not cancelling out like we experienced with the Sentra.
Instead the ski pass-through showed off the massive (and expensive) Human Reign Unleashed amp for the front stage.
Another example of the power of going rear-fire, the awesome Chrysler 200S build I did for one of my friends. Rear-firing 15" Image Dynamics sub (sealed). This system was probably the most amazingly low-playing setup I've ever done. The lessons learned from other builds showed me that, despite the fact the seats fold down and there's a shelf to port through, our best bass performance came from a rear-fire trunk setup. Best by a long shot.
