Stability Control.....
Started by panther427, January 04, 2014, 07:31:07 PM
jmr061
Quote from: SwampRat on February 22, 2014, 01:23:41 AM
Quote from: jmr061 on February 22, 2014, 12:10:17 AM
I'd have to pull the wire diagrams again but yes the wire doesn't exist in non PP SHOs and correct I am my own Ford IDS mechanic lol
Not sure what IDS is but are you familiar with PID's ?
If so , help on this Post would be MOST WELCOMED :
http://www.ecoboostperformanceforum.com/index.php?topic=2118.0;topicseen
Can't help you out with that. IDS is Ford software that the service departments use. It doesn't tell me what the PID id is for each parameter.
Jason
16 Edge Sport
jmr061
So did anyone check their nonPP to see if the wire is there?
Jason
16 Edge Sport
dalum
Nope, I don't plan to have my dash apart again any time soon.
2013 Non-PP SHO
wasinger3000
On a somewhat related note. Does anyone know if these cars have the ability to select steering feel like on the 13' mustangs?  Not sure if there is anything as build data.
Sent using smoke signals.
13' GTCS, will be missed.
jmr061
What does the 13 mustang do?
Jason
16 Edge Sport
SHODYOU
The Mustangs have different settings for the epas system... there are three settings, basically comfort-sport. Obviously gets more aggressive as you go up.
jmr061
Yeah that won't happen with the SHO
Jason
16 Edge Sport
wasinger3000
One can dream.... hah
Kevlar_07
Can anyone confirm the work around works? and if so what block of the as build do you need to change?
Kevlar_07
Quote from: ZSHO on November 27, 2018, 04:11:06 PM
It was DOA IIRC!  Z
https://www.ecoboostperformanceforum.com/index.php/topic,3764.0.html
Should have made my question more clear I have a 15 non pp sho and want to add the ability to shut off the AdvanceTrac by adding the switch and wire to the IC and updating the asbuild data. Wanted to know if anyone had tried to do this and if it worked, and if it does what block of the asbuild do you need to change? Im currently compiling a list of asbuild data lines that are different between the pp and non pp versions but I don't know what they correspond to. Thanks
Quote from: Kevlar_07 on November 27, 2018, 04:54:52 PM
It was DOA IIRC!  Z
I would try to contact Jason username is (JMR061)! He also has a new updated site & email @ jason@FLVPmods.com or http://www.flvpmods.com/ .Z
So reprogramming the IPC and changing the ABD File while you can put the cluster in engineering mode and find the Build data! AWesome indeed.  Z
nickstewartroc
#44
Sweet! Going to have to see if I can do this to my 13' Flex...
Quick overview of what seems to need to be done for this
Repin pin 18 at the instrument cluster
ABS 760-03-01 needs changed to  "4001 AC"
IPC: Changed all from PP
Current:
2013 Ruby Red Flex Limited EcoBoost, Unleashed Tuned, drop in filter
Gone but not forgotten: 2011 SHO Non-PP in Black Tuxedo Metallic - Catback, DPs, Stoptech Z23s, MDesign CAI, LMS Tune
