XSport front lic plate delete
Started by bigmoneycloser, December 21, 2013, 11:12:35 AM
bigmoneycloser
So I decided I was gonna remove the front license plate. Even NJ frowns upon this..
Oh well...lol
Here are some pics..
And the part I used from auto zone to fill plate bracket holes..
It took 2minutes..lol
2014 Explorer Sport 401A
Cool.  I have been thinking about that.  I have touch up.  Maybe a good ten coats would match them up!
EcoBrick Bob
A friend in IA came up with a flip up plate for his Vette that has become a traveling flip-up as he gets a new one every year. He flips it up when he drives it, as patrol stopped him routinely before and started ticketing him (no more warnings,,).  You might want to try something like that if you have issues.
My FL dealer put their "Tamiami Ford" plate on my Flex, even though Florida doesn't require front plates.  I tried filling in holes... plugging holes.. painting holes... and finally put a "Naples Zoo" plate on front... because I am an ANIMAL!!! (that needs to be locked up most of the time... but I digress...LOL)
Naples, FL & Clear Lake, IA
Quote from: bigmoneycloser on December 21, 2013, 11:12:35 AM
Oh well...lol
Cool idea... and looks great!
I prefer the smoother look too..as you can see in my avatar to left.  Thank goodness AZ doesn't require front plates!
FracaSHO
Front plates are required by law in IL.  But in 11 years and 3 cars with no front plates, I have only been scolded by a cop twice. Both times I was pulled over for a different reason, speeding.
Brad
2010 Tuxedo Black SHO w/ PP
Quote from: DJE624 on December 21, 2013, 11:16:28 AM
It would.. It's one of those small things that makes a big appearance improvement. maybe use an airbrush like for plastic model cars to save paint... from any hobby store.
I was lucky... mine came without holes.
It's a cheap part I'm sure. May try it.  The problem is that the White Platinum touch up is just this side of clear.
Quote from: DJE624 on December 21, 2013, 11:48:57 AM
The tux black touch-up is a two step... base and CC... I'm believe platinum is the same... http://www.amazon.com/Motorcraft-Touch-Platinum-Basecoat-Topcoat/dp/B00BR05EEY
Lanson
If you want to have them pre-shot with paint, these guys do a good job
http://www.bumperplugs.com/index.php?route=product/category&path=1_11_78
I've got a set installed on my Flex.
I don't have an EB but I am an avid modder and happy to help the community and learn/grow.  Pretty good with audio and wheels, my build and discussion threads are here in the forum.  2013 Flex AWD N/A
Audio:  Dayton Reference home speakers in front stage, incl. 2-way passive custom pillars 2.5" mid, 3/4" tweet, 2-way passive custom center channel 5" mid, 3/4" tweet, 8" midbass in doors, Vibe UK amps, JBL MS8 processor, Optima Yellow-top custom-wired, Exile subs in spare tire well
Mods: H&R, K&N, 22x9 & 22x10 3 piece forged wheels 265/35-22 Toyos, SCTX4 w/ 91 oct. Torrie tune
bigmoneycloser
Like a  dumbass... I tried to rub out the very minor scratches with a turtle compound wax..
I went a little too hard I guess and it looks like I rubbed the clear off..
Not very bad and most won't notice... But I will..
Is there anything out there that can restore or am I body shop bound?
Thx
If it's just a little cloudy you might be able to shine it up with a little carnauba wax?
bigmoneycloser
Yes
Just cloudy.
I will try that tomorrow.
Thx
bigmoneycloser
You can hide it with wax... carnuba definitelyvwill do it, but it melts at1400, so you'll be chasing it frequently in the summer sun. You will also lose the UV resistance offered by the clear coat so it will eventually fade and create a hologram of the area no matter what you do besides an actual repair.
Clear coats only run about .3-.4 microns thick on the Fords... for comparison, a red blood cell is 7 microns in diameter.
There are several CC repair kits available, just get one intended for cars or aviation use... and ford will sell you the CC. (I'v always done it with Ford paint)  You could try a couple of coats of new clear coat with an airbrush locally on the area.  Do a light scuffing with 0000 steal wool  LIGHT! first, then an IPA wipe to get all the waxes and sealers off the area.... After spraying let it cure and keep it dry for about 7 days.  Then polish the entire area with very fine polish and do final polish with Maguiar's scratch-X 2.0.
If you try to repair and you can't live with the results you can always go to a body shop...... get a good shop though, they hardley ever finish it like a paint correction job and it sounds like you're particular like me.
