AUdio Control Module Self-Diagnostic Mode
Started by dalum, December 01, 2013, 02:47:13 AM
dalum
Browsing around my '13 workshop manual I found this test mode.  I can't remember if I've seen this or not on here and I thought someone might be interested in it if not.
Audio Control Module (ACM) Self-Diagnostic Mode
NOTE: If the Audio Control Module (ACM) is completely inoperative (does not power up), the part number decal on the Audio Control Module (ACM) chassis can be used to attain the ACM part number.
Turn the ACM on.
Operate the audio system in radio tuner (AM/FM) mode.
Press and hold the eject button, and within 1 second, press the seek up button until the speaker walk-around test begins.
The display indicates each speaker as it is tested.
NOTE: If the speaker walk-around test is the only test required, this procedure can be stopped after Step 3 by turning the ACM off or by selecting exit using the touchscreen.
Once the speaker walk-around test is complete, the following information is available through the "BEZEL DIAGNOSTICS" menu using the audio system control buttons:
NOTE: The AHU Diagnostics refers to the ACM and EFP Diagnostics refers to the FCIM .
Menu
     Sub-Menu
APIM Diagnostics
     Part Numbers
     Software Versions
     Configuration Status
     GPS Information
     Tones Test
     Rear Tones Test
     Touch Screen Calibration
     Touch Screen Activation Test
     Display Test Pattern
     RGB Pixel Test
     Exit Diagnostics
AHU Diagnostics
     AHU Part Numbers/Sirius ESN
     Radio Signal Strength
     Exit Diagnostics
EFP Diagnostics
     EFP Part Number
     Exit Diagnostics
To exit the self-diagnostic mode, turn the ACM off.
2013 Non-PP SHO
IS it purely diagnostic... or can we adjust the configurations?  TIA
dalum
I haven't tried it yet but I assume its just diagnostics.
2013 Non-PP SHO
TSS
FYI:   For 2010 to 2012 MKS/SHO....you get there by pressing and holding the  3 and 6 radio pre set buttons at the same time for about 6 seconds.
Gjkrisa
Would anyone happen to have the process for 2016 Taurus I can't get this to work
Gjkrisa
Quote from: Gjkrisa on April 26, 2017, 02:49:59 AM
Nevermind​ guess I was pressing it wrong or not a long enough from eject to seek
