Ride/handling difference between OEM 19's and OEM 20's (A/S) on non-PP SHO?
Started by jim1274, November 25, 2013, 05:13:30 AM
REDSHOCGO
Going to start looking for some 20's witha black accent somewhat liek the flower wheels kinda have a sweet spot for them
2010 Red Candy Sho 402a option non/pp w/unleashed tune,3 bar map, k & N CAI, Corsa catback exhaust, tints 35% front 20% back vta conversion,plastidipped front grill (matteblack), Curva Concept C7 wheels w/20" toyo proxes +4 and Sony Xperia z running torque pro
2011 Sonata 2.0T Limited tinted
2007 Pontiac G6 GTP cpe w/crab intake,Led sequential taillights, custom exhaust(now gone)
Quote from: REDSHOCGO on February 01, 2014, 08:52:22 PM
Chip Foose has a couple of designs very close to the flower wheel without the width limitations (unl;es you just want 8.5" wide wheels).  His wheels are very well made, but not the cheapest.
http://www.chipfoose.com/ws_display.asp?filter=FOOSE_Wheels
REDSHOCGO
Thanks for the recommendation seen some on tire rack that were close
mval
red:
I've been thinking hard about upgrading my 19" to 20". This is the site that I've found that I personally like the best, as you'll being doing a wheel & tire package. The site shows about every wheel imaginable. Got mine picked out just waiting for weather to get better. A question for anybody, if you're going to get nitrogen in your tires do you really need to spend the extra money for new TPMS's other than minor inconvience of resetting the low air pressure light as will be keeping the 19" for winter usage to save new wheels.
http://www.performanceplustire.com/
Element also a good assortment as well as Victoria Tire, but the above was the best.
Also go to
http://www.willtheyfit.com/ to see how they fit on your car. On the '10 the offset on my wheels thru much looking is 39 & size of tire was 255/45/19 width 8", bolt pattern 5 x 114.3mm.
MikeV
'10 lme 4+93, 160t, 3 bar, w/cust headrest & evo gauge pod,md design cai, ppe dpes, borla cback , vertini 20" cust wheels w/conti dws, ebc slotted rotors w/red pads & mgp caliper covers, viper remote start, cust dipped eng cover,fascia, cai & lids,decals, custom bra, black wrapped spoiler
2017 chally scat pack shaker yellow jacket dd, so sho can be a show queen
Quote from: mval on February 03, 2014, 11:00:21 AM
MikeV
Personally I'd have the TPMS installed and working.  While nitrogen really doesn't leak like air the possibility of a slow leak from small puncture or from the valve stem could potentially give you a low enough tire to result in road damage to those new wheels you're looking at.
MeanKS
anyone have any recommendation on the maximum 'safe' offset for our cars (SHO/MKS) with getting new wheels?
i think the standard offset is 39 or 38.  is 35 too much?
MKS-EB...
Quote from: DRII on February 04, 2014, 01:18:06 PM
I don't believe +35 is too much , that is what My 20x8.5 Giovanna Killis are.
mval
dr:
using the site above a 35 offset should work find. I checked other sites like that one & using the wheels like kbecks with a 35 offset, not sure what his tires but with 245/45/20 tires should push tire out only about 10mm. that is starting with 255/45/19 on 8" wheels which the standard without PP are. That exactly my plan. going to go with conti dws's & vertini wheels w/35 offset. If somebody thinks i'm wrong please correct me, as am low tech. but 10mm isn't very much.
mikev
