9006 HID bulb in a 9012 socket?
Started by abnjeffy, November 22, 2013, 01:05:17 PM
abnjeffy
I'm looking to purchase a set of HIDs for my 2013 Taurus. I can only find the 9006 kits, which are nearly identical to the HIR2/9012 bulbs used in the 2013 and 2014 models. However, there is a slight difference in the top locking tabs. I have read about people modifying 9012 bulbs to fit in 9006 sockets, but I am going the other way since there are currently no 9012 specific HID kits that I know of.
Does anyone know specifically how to make a 9006 bulb fit in a 9012 socket? I would prefer to modify the bulb and not go chipping away at the headlight housing, that is if it's even necessary
---2013 Taurus Limited, non-SHO---
BigPelo
That's what I did: 9006 and grinded a part of the plastic bulb. I have a pattern I could share with you on how to do it.
You don't need to touch the housing.
You have a Canadian car?
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
abnjeffy
No my car s american.  Is there a difference?
I'd appreciate any help you could provide.  What did you have to grind on the bulb?
BigPelo... Could you post it for everyone... I'm sure many are interested and it could make a great "How To".  TIA
BigPelo
Canadian car are sold with halogne light. American SHO should come with HID. Because I am Canadian, I upgraded my headlight to HID.
I will scan my pattern into pdf and post it here later this weekend.
I believe you need to trim 9012 bulb tabs when fitting into a 9006 headlamp socket, but no trimming is required when placing a 9006 in a 9012 socket.  You should be OK.
9012 into a 9006 headlamp socket:
http://store.candlepower.com/mohirbuba.html
http://shnu.us/HIR%20Trimming%20Stock.htm
Interested in seeing your pattern, Big Pelo!  Thanks in advance for putting it up.
abnjeffy
Quote from: BigPelo on November 23, 2013, 12:56:09 AM
Mine isn't an SHO, just a lowly Limited model.  I would appreciate the template, thanks in advance
abnjeffy
BigPelo
Oupss, forgot you!
I will try tonight after work. In the meantime, here's a solution:
http://www.carxenonhidkits.com/high-and-low-beam-9012-bi-xenon-hid-conversion-kit-with-slim-ballast-for-ford-taurus-with-halogen-2013/
Might not be as high quality as www.theretrofitsource.com but at half the price, I would try them.
BigPelo
Finally made the pdf. Sorry it tooks so long. E mail me so I can reply with the doc attached.
explorergotoluvit
#11
if your interested in doing it the right way (well in my mind) so your not brighting everyone you should look into these www.lightwerks.com. Having the right projector helps not to bright other. its crisper lighting on the road for yourself as well..
2013 explorer sport
LMS tuner stat 160 3 bar magna flow v8 91 map
k&n H&R spring
retrofit FXR bi-xenon projectors done by lightwerkz
all lights replaced with leds from daytimebrightlites
explorergotoluvit
Thanks I for get its .net and doesn't help I mis spelled it
2013 explorer sport
k&n H&R spring
