Torque Pro setups?
Started by Scott13SHO, August 07, 2013, 11:00:13 AM
BigPelo
#15
Display is a 5.7 inch Galaxy Note3 with RaceMeter add on for Torque Pro. We can't see the shift light but they are twelve of them on top. They started lighting up at 4000 rpm until 5500 where they all flash. Temperatures are in Celsius and speed in km/h.
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
Mac98SHO
Quote from: BigPelo on November 13, 2013, 10:40:55 AM
Quote from: Mac98SHO on November 13, 2013, 09:20:00 AM
I used these guyz for my mount:
http://www.proclipusa.com/
A bit pricey but I like the different options.
Yes they are but, I was attracted it to how the mounts were constructed(molded to the tablet).
2013 SHO w/Performance Package (Tuxedo Black)
Air Raid Intake
X-pipe with Stock Mufflers
X4 SCT w/Unleashed Tunes
SRT82ECOBOOST
If I ever go the route of needing gauges, I think I would try to base my system off from using this interface:
https://www.coastaletech.com/mytouch.htm
Run Torque through your smartphone and then use the built in center display of the vehicle to display gauges. Not 100% sure this approach would work, but damn it would be nice if it did.
twnscrw13
I'm using a Ram Mount: http://www.rammount.com/Products/XGripMounts/XGrip7TabletMounts/tabid/4690/Default.aspx
This is the third mount I've tried and I like it a lot. Very solid, doesn't shake.
2018 PP, blue. Sony, Navi. Stock.... For now.
BigPelo
Quote from: twnscrw13 on November 14, 2013, 02:26:08 PM
I see you are monitoring knock. I didn't find which sensor gives this info yet.
ecoboostsho
twnscrw13
