Torque Knock PID - may have some progress...
Started by ecoboostsho, November 08, 2013, 09:47:16 AM
chrisc321
THANK YOU! This thread finally helped me after searching for 4 days to figure out how to add KR to torque.  I know I'm bringing it back from the abyss, but I felt the need to say thank you.
ecoboostsho
Glad it was helpful! Have you seen the stickied thread for the other Torque PIDs? It has a lot if info...
chrisc321
Yes! Very impressive.  Thanks for pointing me there.  As an F-150 driver, I really like the civility of this forum.  Its refreshing.  However, the whole having to answer 5 verification questions before replying to a thread is trying... LOL
Quote from: chrisc321 on April 30, 2015, 10:59:42 PM
Huh?
ShoBoat
X2 what questions?
2012 Pearl White CTS-V Stock
If that is happening when you try to post, please pm SHOdded because something is definitely not right....
Part of the anti-spam effort.  Only when you initially start posting.  Should be fine after a couple of posts.
ShoBoat
Just thought I would post here KR does not work on the 2016 Fusion 2.0EB. Also LOR does not work correctly. I am going to see if Forscan works and report back.
loweredd
Has anybody seen a 127 number on the gauge on this? In high gear with slight throttle, it shows 125 to 127........
2010 Eco Flex
Map, plugs, thermostat, 91 Torrie Tune.
That looks like the actual mV reading returned by the piezoelectric knock sensor, not knock count.  Once the mV reaches the threshold value, then a knock count is registered.
loweredd
Here is where it did it again today. 6th gear, cruise set, lugging uphill.
LOR WAS at -0.7, I think I got some weak 91 last week, so I put in 3 gallons at a different station, and it went to -0.9. I think the high number is when it checks for knock, kind of like SHOdded suggested.
2010 Eco Flex
ecoboostsho
What's the PID and formula you are using?
Sent from my XT1096 using Tapatalk
loweredd
PID is 2203ec and equation is (A)/2+(B/512)
2010 Eco Flex
