The best I can explain it so far, From what I can see, the max boost is down sometimes to around 13.6 psi or so, although I've seen it go back to 15.3 a few times. 15.3 is what I was getting with 93v6 all the time.
A/F ratio seems to be as low as 10.6, only briefly, but now seems to run 11.1 to 11.3 more under WOT. On WOT, it would jump to 11.1 then sometimes drop quickly to 10.6 or 10.7 then back to 11.1 and up. It's definitely not running in the 10's as much anyway.
I'm using Dashcommand, so I only know how to read in playback mode, which does also record the highs and lows. Hopefully this is some help.
