Transverse Intercooler discussion
Started by bpd1151, October 21, 2013, 05:37:08 PM
EcoBrick Bob
Seriously...  4DR, when I removed my stock grille and installed the Carriage works one, I removed a big plastic grille back panel.  The Carriage works grille also sticks out slightly farther than stock 3 bar Ford grille.  So, I'm wondering if it might be possible to place the Air to Air intercooler a bit higher and behind the top grille.  Will check out space when I get to FL where I can work without a snow suit and gloves.  Thinking there may be space for the 500 hp unit.
Which of the water to air units are you considering to go where the stock CAI fits?
Naples, FL & Clear Lake, IA
Similar to EBB.....
When I removed my factory grilles (both upper & lower) and swapped them for (what was at the time ---Mobsteel) custom grilles....
I too removed a good size chunk of all that plastic crap from the factory set up.
I just recall off hand, due to the fact I've had my front clip off multiple times at this point, that there was / is a "decent" amount of room behind that upper grille area, just atop the front bumper.
I'd be inclined to think that something could be fab'd for sure, & installed in that location.
I would say w/e vendor does decide to take on the project, that they should just automatically calculate for those SHO owners rocking the PP Pkg from the factory, as those include the Auxiliary Coolers, in particular the Aux Trans Cooler which takes up the space in that lower grille opening / area.
Not to mention, there may be other goof balls out there (besides me) who have the NON-PP Pkg from the factory, but retro-fitted those Auxiliary Coolers, so my lower grille opening is occupied.
I'm out clothes shopping with my 12yr old at the moment, & taking her out to dinner after that, so i'm not home....
However, where is AMR's facility located out of curiosity?
Sent from my DROID3 using Tapatalk 2
FracaSHO
#17
I believe the aux oil and trans coolers weren't added until 2013, due to the fact they were added for the police cars. I don't believe the 2010 to 2012 SHO's with PP have the oil and trans cooler. I hope in wrong.  That would be 2 less things to add.
Brad
2010 Tuxedo Black SHO w/ PP
EcoBrick Bob
True, but some people added them to their earlier vehicles.  Personally, I need a tranny cooler.
FracaSHO..... you are correct.
However, EBB got my point directly.....
There are gonna be, if not quite a few who have already, added that Aux Tranny Cooler, & the Auxiliary Oil Cooler.
I can't even begin to tell you how much both of those have helped me in my own application.
Much like I believe having (some company) fab up an upgraded intercooler for our cars.
If not, y'all should pay close attention to the developments 4DRHTRD is undertaking in the water/air cooler option.
TouchOfEvil
Nobody loves the sports. =[
i need a intercooler too!!!!!
2014 XSport
FracaSHO
Problem with air to air isn't just having the room to fit, it needs to be in the right spot to be at its full potential.
Can anything be done to the factory intercooler to it?
Brad
Josephm
A top mount with a hood scoop would be an interesting option but not the best option..
12' Flex EB
Unleashed X4
3rd Cat delete
AMR Performance
Quote from: bpd1151 on October 24, 2013, 07:45:44 PM
We have 2 locations.
NY & CT
-Robert
Yep, finally got onto an actual notebook and looked up your info.
For anyone interested, particularly you SHO owners on the far East Coast.....
Please visit AMR's website ------> http://automasteramr.com/about/
By providing AMR staff with your vehicle for testing and/or design work of a hypothetical, proposed intercooler upgrade, this will likely prove beneficial not only to you as an individual donor, but also the SHO community overall.
Thanks AMR for considering this potential product, and hopefully someone here steps up and contacts your company to work out the particulars.
Mike :beer:
casperl878
68_GT
AMR,
If you build it we will....
buy it !!!!!
Assuming the benefits justify the cost and effort of the upgrade. I love the idea of a simple intercooler swap since if probably wouldn't really effect the car in any other way other than to just add power.
Great opportunity!! Thanks bpd and AMR!
If the "/about" link is dead... just use http://store.automasteramr.com/ to get the site
281Thunder
Quote from: Josephm on October 25, 2013, 01:21:40 AM
It works well on the Subaru's since they have room behind the top mount for airflow. I think our engine bays would be too cramped to fit the intercooler, and have good airflow across it.
What about running two smaller side mount intercoolers like you see done in aftermarket setups on...I wanna say Vettes?
2011 SHO
Josephm
That is a lot of piping though.
Thinking an inter cooler for each turbo? Is that possible?
12' Flex EB
Unleashed X4
3rd Cat delete
