TCE Wilwood Brake Kit Front and Rear
Started by SwampRat, October 21, 2013, 08:03:55 PM
SHODYOU
From what I understand, stock 20's require a 10mm spacer to cleae the front kit. Not from rotor interference but from the fat caliper. TSW might have more clearance in this area...
TSW , Giovanna and Niche make several wheels that have enough clearance for these "fat" calipers. My Giovanna Meccas have a + 38 offset .  Also look for rims that have thin spokes that will be less likely to have clearance issues.
Given that info, I would bargain to say that the Nurburgring's I'm currently sport'n on my '10 SHO, oughta be just fine.
Hopefully that's the case, as having to save up for this front & rear kit offering, ON TOP of having to purchase new wheels & tires would be a financial nightmare.
Sent from my DROID3 using Tapatalk 2
Quote from: kbeck59 on October 27, 2013, 09:04:23 PM
I will try to try to stress to my fellow SHO owners that all  GO and no SLOW is not a good thing !!
Several of these gen 6 SHO's are putting out 500 to 600+ HP in these " bricks" and with only minor brake upgrades. ?!?!?!
I have noticed a HUGE improvement in braking power with Shorter distances needed when braking heavily  ......
THERE Is NO Doubt that is brake SETTUP IS A major improvement over the stock PPE setup !!
I amazes me that people seem to be more concerned with Dumping HUGE amounts of money in more HP with very little concern in stopping power .....
In time  I will do Engine MODS to include high flow catted down pipes and aftermaket turbo's with a livernois tune soon ; more once I learn a little  about other options .
You are right. We have not talk much about brake. Here are threads that we have had and sorry lot more were done on the other Forum that were lost and never made it over here.
http://www.ecoboostperformanceforum.com/index.php?topic=362.0
http://www.ecoboostperformanceforum.com/index.php?topic=746.0
http://www.ecoboostperformanceforum.com/index.php?topic=1381.0
AND MORE LOOK UNDER BRAKES here on the forum.
Just an update for anyone still dreaming of a Big Brake Kit ......
TCE/ Wilwood Brakes are performing perfectly and are wearing very little to my amazement and pleasure    ..
These things bite and stop on a dime ..
I paid carefull attention to bedding the pads in and fade is non existent .....
8000 miles on brakes and could not be happier with this setup ..... ! !
http://www.tceperformanceproducts.com/flex-/-sho/kits-23/
bigmoneycloser
I second that statement... I have about 1500 miles on my TCE/wilwood kit for the XSport and I have zero issues  and this thing stops on a dime. We have had a lot of bad weather since the install but I really took the time to make sure rotors and pads were broken in properly...
They LOOK Great and perform Great too...
2014 Explorer Sport 401A
Todd TCE
We can now offer the front kit in 15" diameter btw.
Todd
TCE
Quote from: Todd TCE on April 02, 2015, 07:37:55 PM
Not sure if I am the 1st (to order the upgraded, 15" rotor) but I did finally place my order this past week (for the front axle only at this point) and besides incorporating the larger rotor, I also ordered a whole host of addt'l upgraded goodies from TCE.
A BIG shout out to Todd @ TCE for being nothing short of stupendous in every facet of the word, for assisting me with (& processing) my order.
I very much look forward to not only receiving the front axle set up, but am already tucking the necessary $$$ away to order the rears in due time as well.
Thanks bunches Todd! :thankyou:
Looking forward to the upgraded brakes, Mike :D
CroR1
bpd, keep us posted if the front wheel clear the calipers.
also, it would be nice to know from the people that have this kit,just how much offset is needed and what type of wheels, to clear the brake caliper without mounting a wheel spacer.
66 Galaxie
Quote from: cror1 on April 03, 2015, 12:13:14 AM
I will do so.
Although my results are probably not applicable for most,  as not only am I running an aftermarket wheel, but I am also running a larger width wheel too.
Got two different shipments coming.
One tomorrow which includes the calipers & pads & a second delivery due to arrive this Thursday that includes the rotors.
Pictures forthcoming. Both pre & post install.
I'm still toying around with PC options as I'd like to retain some semblance of the black / white theme..... I may just have the rotor hats PC'd in white & leave the calipers as they were shipped in black PC.
66Gal i'll mention your question to Todd & hopefully he'll reply with an answer for you.
I had a chance to really take a good look yesterday at the brake kit on (BMC)X-SPORT,was truly impressed by the looks and quality,black calipers with the drilled/slotted rotors and gives it that WOW factor APPEAL to it,good luck on the install BPD and enjoy.Z
Quote from: ZSHO on April 05, 2015, 06:01:04 PM
Yet to lay my eyes on a TCE kit, envious!
bigmoneycloser
The 15" kit will be bad ass!!
Enjoy!
