Blacked out 2.0l ecoboost fusion
Started by Fordman77, October 12, 2013, 12:49:38 PM
Very nice..... that wheel looks HUGE!
Do you have the tech specs on what was done to upgrade it?
Sent from my DROID3 using Tapatalk 2
Fordman77
It's a GTX2867R with a .6 a/r housing with an internal wastegate but with the option to run external. with the 2.0l exhaust manifold inaugurated into the engine it was easy to designs a exhaust manifold pipe to meet up with the engine and all of the other oil and water fittings atp has included lines and fittings for all the stock locations. It's amazing they do great work!
-Fswerks (Randy) 93 oct. tune, -OCD Speed 3" downpipe,
-straightline performance 3" cbe, -levels performance 2.5" hot side charge pipe,- straightline performance 3" turbo inlet pipe, -steeda air box replacement -ATP FMIC upgrade
-Eibach sport springs -steeda sway bar-snow performance water meth kit
Yea, their work is truly impressive.
I know I was in just as much awe as it sounds like you are....
I'm elated with my ATP's installed just one week ago.
Even sans the proper tune, I am still noticing increases/improvements across the board.
Those guys/gals over ATP have got turbo upgrading down to a science, that's for sure.
Fordman77
Yea they do I would recommend them to anyone and hope more of the ecoboost owners take advantage of them! They really seemed to have fully bought into all ecoboost engines I hope that they continue to make more products and continue to support the community.
Also where did you get your engine tuned at?
All of my tuning has been performed through LMS.
I am waiting to finish up saving/paying for the hard pipes that 4DR's group buying.....
Once I get those done, then i'll be hitting up LMS for a new dyno appointment.
Good thing Winter's approaching, as the mere thought of all the impending ice/snow etc. will force me to drive somewhat cautious.
So I have a little bit of time in other words.
Sweet wheel of fury!  That's one nice piece of equipment there.  Did ATP say what gains you can expect?
Fordman77
Quote from: SHOdded on October 29, 2013, 09:04:42 PM
It's made for a focus st and they were pushing 400+ but with my internal, fuel system and transmission I'm going to shoot for around 350 hp
Josephm
Are you running the stock fuel pump? Or did I miss that part where you said what you were using.
12' Flex EB
Unleashed X4
3rd Cat delete
Fordman77
I'm using the stock fuel pump but will be running a conservative tune until fuel pumps and engine internals can be upgraded.
melc
Quote from: Fordman77 on October 29, 2013, 09:17:55 PM
The suspense is killing me :smiley5:!! Thanks Fordman77 for being the pioneer on performance mods for the Fusion 2.0EB :rock:
2011 Black SHO PP
Livernois and Unleashed 91 octane tunes
Unleashed W/M system
Auxiliary trans cooler
AirAid CAI Eiback Springs LED lamps inside
Fordman77
Finally found a tuner!!! Not too much longer before I will have the turbo installed with more dyno information!
Sounds good!  Can't wait to see the before and after curves.
Man, that thing is slick. Slicker than snot!
