Consolidated Ecoboost Fueling thread
Started by 05yellowgt, October 07, 2013, 04:28:00 PM
Josephm
Did i read that correctly that you are running 15 Gal of E85? 15/18.6, that's an 81 percent mix. Be careful to monitor A/F, the mazdaspeed's that ran over 50 percent mix's got sticky fuel pump issues
12' Flex EB
Unleashed X4
3rd Cat delete
StrawHatShinobi
My tank is 36 gallons.
Bob, would a stock F150 pump work in your basket?  I had mine flow tested at DW it was flowing 290lph at 40psi I believe.  I see from the pictures you guys don't have much for working room.
'13 Eco screw FX4 - THE56 turbos, AEM Dry flow, MAK DP, 4" exhaust, meth injection, Walbro 450 lift pump, 2"HBS level, 20" Fuel Nuts on 33" Toyo M/T's
Josephm
that's a huge tank. disregard previous statement.
12' Flex EB
Unleashed X4
3rd Cat delete
Quote from: Josephm on December 06, 2013, 03:06:19 PM
No issues with my car for 2K miles on full E85, just FYI
Quote from: redsand on December 06, 2013, 04:58:59 PM
No those pumps won't work in ours, you have Walbro 430 with the ledge, we have a regular Walbro 255 body.
StrawHatShinobi
Also I thought the MS's later discovered it wasn't the E85 causing the gunk issue?
In any case, my lambda hasn't really looked any different under various throttle input than when I'm running a normal tank of gas.  It does kick the mileage in the balls though and with it being -7 out that doesn't help either.
Josephm
Last i heard, they never figured out what caused the gunk, but they just know that past 50%, they had issues. I haven't been reading much on the mazda forums since i got my EB since they make you pay to read everything witch is BS.
12' Flex EB
Unleashed X4
3rd Cat delete
Josephm
Quote from: 4DRHTRD on December 06, 2013, 05:27:26 PM
Your flex? I never seen you ran a 100% E85???
12' Flex EB
Unleashed X4
3rd Cat delete
StrawHatShinobi
Wow, they make you pay to read the forum? That is BS.  I will probably try a higher amount of E85 next go around since I doubt this was true E85. They do sell E40 or 45, at that station so I may just try a full tank of that depending.
Josephm
Ya they have a VIP section, witch is ridiculous to being with
12' Flex EB
Unleashed X4
3rd Cat delete
Quote from: Josephm on December 06, 2013, 08:02:47 PM
As soon as I went dual itfp I went 100% e85. The car would run 50/50 e85 on stock fueling at 500hp thanks to the dual pumps.
Sent from my SCH-I545 using Tapatalk
EcoBrick Bob
Quote from: 4DRHTRD on December 06, 2013, 05:27:54 PM
4DR, did you ever find any Ford pumps that would fit in our basket or fit in our tank that are larger volume than current pump????
Naples, FL & Clear Lake, IA
Any regular pump like a walbro 255 sized pump or dw300
StrawHatShinobi
I've got a DW in my garage too, never been used. Its been in tank but never used. Don't think its a 300 though, 265 comes to mind.
EcoBrick Bob
Quote from: 4DRHTRD on December 06, 2013, 09:47:19 PM
How much bigger are these than the stock LPFP?
