2016 Taurus Police Ecoboost problem
Started by PDSHO, January 04, 2025, 02:16:18 PM
PDSHO
Hello, I have a 2016 Police Taurus with eco-boost engine. I live in the country and have been having trouble with rabbits getting up in the engine bay and chewing up wires.
The car has a misfire and will only rev to around 2200 RPM. So far I have found that they have chewed off at least one wire to a fuel injector, wires to both BOV towards the back side of the engine, and a bundle of wires just above the High pressure fuel pump.
I have been totally confused looking for the correct harness for this engine. My son is really good with wiring and thinks we can fix what I have, if I can find an upper engine harness, and maybe we could even take wires and connectors from a donor. Thoughts?
Thanks Greg
2013 Taurus Police Interceptor. AWD, Eco-Boost. SOLD
2015 Lincoln Navigator L, 4x4, Eco-Boost.
2016 Taurus Police Interceptor, Eco-Boost
2014 Lincoln MKS Eco-Boost
https://www.fordpartsgiant.com/parts-list/2016-ford-taurus/electrical/wiring_engine_and_transmission.html
GG1Z-14290-L
Wiring Assy
Fit Note: HEADLAMP PREP PACK, With Level 3 Headlamps, With Level 4 Headlamps, Less Wiring Prep
Fitting Vehicle Options: 6 Cyl 3.5L DOHC T/C
Callout Name: 14290
$870.00
$584.64
Add To Cart
GG1Z-14290-M
Wiring Assy
Fit Note: HEADLAMP PREP PACK, With Level 3 Headlamps, With Level 4 Headlamps, WIRING PREP
Callout Name: 14290
$943.33
$633.92
Add To Cart
GG1Z-14290-N
Wiring Assy
Fit Note: Adp Spd Cnt-Coll Mit & FWD Sns, With Projector Beam Headlamps
Callout Name: 14290
$828.33
$556.64
Add To Cart
Ford GG1Z-14290-P
GG1Z-14290-P
Wiring Assy
Fit Note: Adp Spd Cnt-Coll Mit & FWD Sns, High Intensity Discharge Headlamp
Callout Name: 14290
$830.00
$557.76
Add To Cart
GG1Z-14290-Q
Wiring Assy
Fit Note: With Projector Beam Headlamps, With Speed Control
Callout Name: 14290
$850.00
$571.20
Add To Cart
GG1Z-14290-R
Wiring Assy
Fit Note: High Intensity Discharge Headlamp, With Speed Control
Callout Name: 14290
$850.00
$571.20
Add To Cart
https://parts.levittownfordparts.com/oem-parts/ford-engine-compartment-wiring-harness-fg1z14290q
looks like sho and pi are same per fitment but best to ask a parts counterperson to confirm
VEHICLE FITMENT
Year   Make   Model   Body & Trim   Engine & Transmission
2016   Ford   Police Interceptor Sedan   Base   3.5L V6 - Flex, 3.5L V6 - Gas
2016   Ford   Taurus   Limited, SE, SEL, SHO   3.5L V6 - Flex, 3.5L V6 - Gas
PDSHO
Thank you for the reply and links, I talked with my nephew who is a service tech and he suggested I make a list of all damaged wires and go to Ford for repair pigtails.
I thought that would be a lot of running around, my closest Ford dealer is 20 miles.
So I found a 2016 engine harness on eBay from an Explorer sport eco-boost. It arrived yesterday and looks like it has everything we need plus more. I will report on how it goes, thanks again.
My war on rabbits continues!!
Greg
wabbitses ... lol. best of luck.
PDSHO
Today my son and I tore into the rabbit damage. everything we needed was on the donor harness.
My son used to be a tech at a Cat dealer, and did a lot of electrical custom work on machines for the railroad. He is a wiz and I just stayed out of his way, lots of very small butt connectors, solder and shrink tubing, way too tedious for my old eyes! Maybe an hour later I was test beating the car, no miss, power is back, no CEL!
Thanks Greg
