December 10, 2023, 12:01:25 AM
Author Topic:  MKS temp gauge issue.  (Read 1436 times)
Offline ChaudMasterFlex
  • Newbie
  • NH
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 0
« on: October 05, 2023, 07:24:43 PM »
I have a 2014 MKS ecoboost and I’m having an issue where the temp gauge randomly drops while driving. It never goes above the “normal” spot, but always drops with no rhyme or reason. Sometimes it’s just a single step down, other times it drops quite significantly. Temps seem normal number wise (cruising 194-200, and jump to 209-210 when idling). I put a new 170 t-stat in yesterday and spent about an hour trying to bleed it (hoses weren’t collapsed, both were hot). Felt like I lost more coolant than I put back in too. It’s doing the same thing with the new t-stat (feels like it’s doing more tbh). Also, water pump, chains, guides etc were changed 1k miles ago. It’s driving me nuts, any ideas?
« Last Edit: October 05, 2023, 07:28:48 PM by ChaudMasterFlex »
2014 MKS - AFE intake, colder plugs, 3-bar map, 170, MSD coils
2010 Honda Odyssey
2014 WRX - fully built  402WHP 378WTQ
2014 Highlander
2001 Corolla 478k
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13073
  • -Received: 4268
  • Liked:
  • Likes Given: 190
Re: MKS temp gauge issue.
« Reply #1 on: October 09, 2023, 03:56:21 PM »
certainly could still be air pockets but havent seen this erratic behaviour in a related way. how have you been bleeding the system. you can use a lisle spillfree funnel to help with the process. make sure that while idling/parked, the reservoir is the high point of the cooling system. parked on a curb or sloped driveway or ramps on that side will help.
battery voltage weakness could potentially cause this type of issue. or pest-damaged wiring.
  • Newbie
  • NH
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 0
« Reply #2 on: October 14, 2023, 10:37:12 AM »
Battery is new. I've been bleeding it with the cap off and a funnel. It's just driving me nuts.
2010 Honda Odyssey
2014 Highlander
2001 Corolla 478k
Offline Thomks
  • Newbie
  • Iowa
  • -Given: 0
  • -Received: 0
  • 2013 Lincoln MKS
  • Liked:
  • Likes Given: 1
« Reply #3 on: December 02, 2023, 12:18:59 AM »
The thermostat is just a valve for coolant to enter, it reaches a certain temp, ie. 170
« Last Edit: December 02, 2023, 12:30:53 AM by Thomks »
2013 MKS EcoBoost: NGK plugs and coils, Livernois 160
