March 23, 2023, 11:20:03 PM
Author Topic:  I'm getting a P0161 code and new sensors aren't solving the issue.  (Read 487 times)
Offline Mike67
  • Newbie
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 0
I have replaced the sensor twice and the first replacement coded again before I got out of the driveway, the second one lasted 10-15 miles and then coded again after I went through an automated car wash. IDK if the car wash caused it or if it was just a coincidence. My tuner thinks I have a bad wire or connection somewhere causing it. I checked the pins on the female connector where the O2 sensor plugs into last time and they looked good to me so that leads me to believe it's upstream from the connector. If I could get my hands on a wiring diagram for the car that would be great. Any recommendations on where to look and how to track the problem down would really be appreciated.2017 Taurus SHO
Offline Macgyver
  • Super Moderator
  • Eastern Pa.......
  • -Given: 100
  • -Received: 396
  • 2020 Red ST
  • Liked:
  • Likes Given: 37
Re: I'm getting a P0161 code and new sensors aren't solving the issue.
« Reply #1 on: February 03, 2023, 12:23:25 PM »
How far have you driven it with the code. Sometimes they are historical and need 60 miles to clear up.
* Recent Topics
Re: Fresh Meat
by Faux SHO | March 14, 2023, 08:15:55 AM
I'll check them out...thank you!...
Pcv issue or turbo seals?
by 13shonuff | March 07, 2023, 04:51:15 PM
I have a 2013 SHO. after my atp turbos blew up from turbine housing cr...
Re: P0016 code, But cam positions in range.
by SHOdded | March 05, 2023, 10:02:43 AM
still not seeing the adverr values. but i checked my logs for our 2007...
Re: New from the Puget sound Washington area
by PDSHO | March 03, 2023, 09:57:38 PM
Re: SHO'Nuff
by PDSHO | March 03, 2023, 09:56:14 PM
Re: 2013 SHO w/pp. Replaced timing chain and water pump. still have issues
by SHOdded | February 27, 2023, 10:17:12 AM
yes recheck the timing chain marks, make sure they line up perfectly.&...
Re: That's the Brakes
by SHOdded | February 11, 2023, 04:34:03 AM
Thank you all for your valuable input. I successfully bought & rep...
Re: EBPF is Backup after planned backend upgrade
by bpd1151 | February 10, 2023, 06:01:03 PM
Thanks to ADMIN for getting EBPF back up and running!Sent from my SM-N...
Re: 2019 SHO extended warranty
by Faux SHO | February 06, 2023, 11:47:34 PM
most if not all dealers do it this way unless you have a working relat...
Re: need solid advice on high flow cat issue.
by ThePresidential | February 05, 2023, 04:59:00 AM
Would it spool up a little quicker?...
