March 23, 2023, 11:14:04 PM
Author Topic:  2023 Special Olympics Fundraiser - Polar Plunge  (Read 391 times)
Offline bpd1151
  • Forum Supporters
  • SHOcago S/W 'Burbs
  • -Given: 2605
  • -Received: 2677
  • SHOGAZM
  • Liked:
  • Likes Given: 0
« on: February 01, 2023, 08:29:39 PM »
Hoping some of my fellow SHO owners here would consider donating to a worthy cause as I've decided for the 1st time ever to participate in my agency's involvement in the annual Special Olympics Polar Plunge Fundraiser.
Below is the link to my profile, which is affiliated with my LE agency.
[URL unfurl="true"]https://soill.donordrive.com/participant/Michael-Kraus[/URL]
Any assistance any of you can lend would be TREMENDOUSLY APPRECIATED.
Please pass along to any other's that you'd think would assist with a contribution as well.
100% of the proceeds go entirely to Special Olympics and the many individuals that benefit from these volunteer efforts.
Thank you VERY MUCH for any help that any of you could lend.
Sent from my SM-N986U1 using Tapatalk
* Recent Topics
Re: Fresh Meat
by Faux SHO | March 14, 2023, 08:15:55 AM
I'll check them out...thank you!...
Pcv issue or turbo seals?
by 13shonuff | March 07, 2023, 04:51:15 PM
I have a 2013 SHO. after my atp turbos blew up from turbine housing cr...
Re: P0016 code, But cam positions in range.
by SHOdded | March 05, 2023, 10:02:43 AM
still not seeing the adverr values. but i checked my logs for our 2007...
Re: New from the Puget sound Washington area
by PDSHO | March 03, 2023, 09:57:38 PM
Re: SHO'Nuff
by PDSHO | March 03, 2023, 09:56:14 PM
Re: 2013 SHO w/pp. Replaced timing chain and water pump. still have issues
by SHOdded | February 27, 2023, 10:17:12 AM
yes recheck the timing chain marks, make sure they line up perfectly.&...
Re: That's the Brakes
by SHOdded | February 11, 2023, 04:34:03 AM
Thank you all for your valuable input. I successfully bought & rep...
Re: EBPF is Backup after planned backend upgrade
by bpd1151 | February 10, 2023, 06:01:03 PM
Thanks to ADMIN for getting EBPF back up and running!Sent from my SM-N...
Re: 2019 SHO extended warranty
by Faux SHO | February 06, 2023, 11:47:34 PM
most if not all dealers do it this way unless you have a working relat...
Re: need solid advice on high flow cat issue.
by ThePresidential | February 05, 2023, 04:59:00 AM
Would it spool up a little quicker?...
