Stock 20" wheel backspacing?
Started by Twol8uluz, May 05, 2022, 10:55:40 AM
Twol8uluz
Since i cant find anything much on the interwebs and apparently cant find it on here with the search function. Does anyone know the back spacing on stock 20" snowflakes 2013? My new wheels are 6.299" and are tucked in quite a bit. They are 8.5" wide with +40 offset so backspacing is the only thing that may be the issue.
Ta2dResqr
20x8 39mm backspace 63.4 hub bore 5-114.3 bolt pattern
Lucy Ford 2015 Ruby Red Tinted Clearcoat Metallic, GearHead AO Performance Tuned - SCT X4, GearHead Intercooler, 3-Bar MAP, EPP Hot Pipes (Plum Crazy), EPP Dual Intake (Plum Crazy), AD Mounts, MSD Coils, JLT Oil Separator, 160 Thermostat, Ortiz Performance Battery Hold Down (Plum Crazy), Hellcat LPFP, 255/45R20 DSW06 Plus, Sync3 Conversion, CYANLabs Syn3, FMods, Jail Broke APIM, Infinity Kappa Speakers, Speaker Baffles, Whelen POV Response Package - (Inner Edge FST, Inner Edge RST, Sidekick, Tracer, LINV2, IONV3, HHS 200W, Howler 200W), Z-Flash, Full LED Swap, Drive Bright DRL Kit, Drive Bright Puddle Light Kit, Ford Sunroof Visor, Window Chrome Delete, OSRAM XENARC Night Breaker Laser, FORScan, OBDLink, Ford Cargo Organizer
Twol8uluz
39mm is the offset, not the backspacing.  Ive already found all of that info. Thanks tho!
Ta2dResqr
Given a 8" wheel with a 39mm offset, backspacing should be 6.04". Compare that to your 8.5" wheel with a 40mm offset which should calculate out to 6.32".
Twol8uluz
Ta2dResqr
That is literally 1/2 of a mm. I am going to guess that there was a thicker spot in paint, a spec of dust, a slightly out of calibration measuring device, poor tolerance on the measuring device, not perfectly parallel surface or any other number of slight variances.
You are also only looking at a difference of 1/4" or 7mm for backspacing difference. Being that the offset is only 1mm different, your wheel should be 1/4" wider in both directions with a 1mm bias towards the center of the vehicle. I'm going to guess that based off that, there is another reason they are "tucked in quite a bit".
Twol8uluz
Exactly! So im not sure why theres so much difference between stock and these.Hopefully you can tell by the pic how tucked in they are
Ta2dResqr
What size tire are you running?
Twol8uluz
Ta2dResqr
By going with a wider rim, your tire sidewalls are probably flexing out slightly and drawing the tread in towards the tire a little (\_/ vs l_l ). Combine that with the very slight change in wheel orientation and maybe that is enough for you to notice. You could step up a size or two in tires to help fill it out (and give you a bigger contact patch). Look at the tire specs for the desired tire and you can compare it to the stock application. There are lots of comparison calculators online. Most tire specs will also give you a max and min rim width and a recommended. Personally, I tend to stick towards the minimum end. This gives the tire a little bit bigger look.
Twol8uluz
Its definitely a backspacing issue and not a tire size issue. Working with tire rack now to split the cost of spacers.
Ta2dResqr
Good luck. Hope it achieves the look you want.
Twol8uluz
Thanks, it definitely does. Already put test spacers on and it did exactly what i thought it would. Only need a 5/16" spacer. 😉👍
