DI fuel pump TORX bolts .. how tight?
Started by TopherSho, February 20, 2022, 10:18:51 AM
TopherSho
I'm not seeing in any detail the recommended tightness for the torx-45 bolts into the base plate for the DI pump?  Anyone do a firestorm/xtreme-DI pump have any input?
Best 0-60 public road 4.35s
ridered74
Quote from: TopherSho on February 20, 2022, 10:18:51 AM
I can tell you that if you over tighten them, they are pretty easy to snap. Use a 1/4 drive ratchet and just turn them until they are tight. Any ugga duggas at all and they will snap. PITA getting an extractor down in there to remove. No need to discuss how I know these things...
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
SM105K
Quote from: ridered74 on February 20, 2022, 09:25:18 PM
Installing those bolts were the most anxiety inducing mod I have ever done on a vehicle.  Lol.
TopherSho
Awesome .... I handle anxiety ... like a molten hot hand grenade Bondo'ed to my hand :P
So make them tight .. but don't be an ape ... i'm so screwed I ape everything :D
SM105K
Quote from: TopherSho on February 22, 2022, 12:55:03 AM
Just remember tighten them down equally.  Remember, you are pushing down against main spring.  Just be careful and take your time.
Ta2dResqr
This is all with the fuel injection pump cam lobe at BDC
Factory specs are:
    NOTE: Clean the fuel injection pump bolts and apply Thread Sealant with PTFE to the bolts.
    Install the fuel injection pump with the fuel injection pump mounting plate and loosely install 2 new fuel injection pump bolts, alternately tighten each bolt one complete revolution until seated. Tighten the 2 fuel injection pump bolts in the following 2 stages.
        Stage 1: Tighten to 10 Nm (89 lb-in).
        Stage 2: Tighten an additional 45 degrees.
Lucy Ford 2015 Ruby Red Tinted Clearcoat Metallic, GearHead AO Performance Tuned - SCT X4, GearHead Intercooler, 3-Bar MAP, EPP Hot Pipes (Plum Crazy), EPP Dual Intake (Plum Crazy), AD Mounts, MSD Coils, JLT Oil Separator, 160 Thermostat, Ortiz Performance Battery Hold Down (Plum Crazy), Hellcat LPFP, 255/45R20 DSW06 Plus, Sync3 Conversion, CYANLabs Syn3, FMods, Jail Broke APIM, Infinity Kappa Speakers, Speaker Baffles, Whelen POV Response Package - (Inner Edge FST, Inner Edge RST, Sidekick, Tracer, LINV2, IONV3, HHS 200W, Howler 200W), Z-Flash, Full LED Swap, Drive Bright DRL Kit, Drive Bright Puddle Light Kit, Ford Sunroof Visor, Window Chrome Delete, OSRAM XENARC Night Breaker Laser, FORScan, OBDLink, Ford Cargo Organizer
TopherSho
tarmstrong
2018 Maroon PP SHO
K&N Drop-in
Previous: 2015 Dark Side Metallic PP SHO
3 Bar, K&N, Tune
ridered74
The good news is you can get 2 replacement bolts for 13 bucks from the dealer....mine even had them in stock.
Just have your hand way down on the handle like right on the socket itself when you are tightening it.
Ta2dResqr
SM105K
ridered74
Quote from: SM105K on February 23, 2022, 12:35:33 PM
Quote from: TopherSho on February 22, 2022, 05:24:51 PM
89 ftlbs ... holy crap
So basically...3 ish Ugga Duggas.
NOOOOOOOO!!!!! Like a quarter of an ugga dugga max! lol!
SM105K
Quote from: ridered74 on February 23, 2022, 08:34:52 PM
What size impact we talking about? LOL.
