- Full Member
- Newb
- Logged
Quote from: TopherSho on February 20, 2022, 10:18:51 AM
I'm not seeing in any detail the recommended tightness for the torx-45 bolts into the base plate for the DI pump? Anyone do a firestorm/xtreme-DI pump have any input?
This is all with the fuel injection pump cam lobe at BDC
Factory specs are:
NOTE: Clean the fuel injection pump bolts and apply Thread Sealant with PTFE to the bolts.
Install the fuel injection pump with the fuel injection pump mounting plate and loosely install 2 new fuel injection pump bolts, alternately tighten each bolt one complete revolution until seated. Tighten the 2 fuel injection pump bolts in the following 2 stages.
Stage 1: Tighten to 10 Nm (89 lb-in).
Stage 2: Tighten an additional 45 degrees.
Lucy Ford 2015 Ruby Red Tinted Clearcoat Metallic, GearHead AO Performance Tuned - SCT X4, GearHead Intercooler, 3-Bar MAP, EPP Hot Pipes (Plum Crazy), EPP Dual Intake (Plum Crazy), AD Mounts, MSD Coils, JLT Oil Separator, 160 Thermostat, Ortiz Performance Battery Hold Down (Plum Crazy), Hellcat LPFP, 255/45R20 DSW06 Plus, Sync3 Conversion, CYANLabs Syn3, FMods, Jail Broke APIM, Infinity Kappa Speakers, Speaker Baffles, Whelen POV Response Package - (Inner Edge FST, Inner Edge RST, Sidekick, Tracer, LINV2, IONV3, HHS 200W, Howler 200W), Z-Flash, Full LED Swap, Drive Bright DRL Kit, Drive Bright Puddle Light Kit, Ford Sunroof Visor, Window Chrome Delete, OSRAM XENARC Night Breaker Laser, FORScan, OBDLink, Ford Cargo Organizer
