Dyno done for upgraded stock turbos 459/521
Started by EcoPowerParts, September 13, 2013, 08:19:45 PM
wasinger3000
13' GTCS, will be missed.
alpine_jake
I feel like every time i do a boost launch only my front wheels are spining. I get some nasty wheel hopp in first.... but i can cherp going into second. Does this seem normal?
2010 Non-pp pearl white, Torrie tuned, 3Bar, Dyno Max mufflers and polished 4"tips, 170 Thermo, slotted and drilled black rotors, ceramic pads, silver calipers, tinted tails, .030 NGK
The spinning of the front tires and the chirp in 2nd is normal,you had to see the grin on my face at first,what tires are you running with,did you ever notice that wheel hop in stock mode?also try playing with your tire psi,also the colder weather can contribute to the wheel hop,good luck.
PokerMunkee
wasinger's car is a beast!
How did you get that enabled?  I'd like to see if my dealer will do it for me..
2011 F-250 6.2 CCSB FX4
Would love to see some 60' times with that sub 4....nice
Rich
wasinger3000
#22
Quote from: PokerMunkee on October 23, 2014, 12:45:26 PM
Thanks! It's actually really simple. Took less than a minute to enter in the changes. Just ask if your dealer has any experience with "as build data" in the ICM.
wasinger3000
Quote from: glock-coma on October 23, 2014, 01:19:06 PM
He'll yeah it is!!  a sub 4sec 0-60... Beast mode!!!
Quote from: SHOnUup on October 23, 2014, 01:22:45 PM
Rich
I would of went to the track last Friday but Torrie is still dialing in the tune. I'm excited to see how it does cause it pulls just as hard past the big numbers.
SHOmanMike84
Quote from: wasinger3000 on October 23, 2014, 10:48:49 PM
Rich
What percentage of meth are you running?
2013 SHO, PP, Unleashed E25 tune, 3bar, aFe panel filter, 170* thermo, PPE catted DP's, 3rd cat delete, Eibach springs, Black powder coated flower wheels.
wasinger3000
Quote from: SHOmanMike84 on October 23, 2014, 11:54:47 PM
Rich
90% Meth/ 10% Water. Works out quite well.
SHOmanMike84
Quote from: wasinger3000 on October 23, 2014, 11:56:15 PM
Rich
Sure as hell looks like it lol. Which kit do you have?
wasinger3000
Quote from: SHOmanMike84 on October 24, 2014, 12:01:42 AM
Rich
It's a devils own pump and controller but I'm using a different nozzle that is recessed 120mm past the intake tube which helps with atomization. Also pushing 13.6 gph at 300 psi. As well as experimenting with a UCL which seems to be helping.
alpine_jake
Quote from: ZSHO on October 23, 2014, 06:28:36 AM
Im running eagle gts on it right now. Nope never did this with the stock tune. Actually it didnt start doing it untill i got some really good BP 93.5 octane instead of the crap KwikTrip 92 octane. Car feels like it added 40 horse with just different gasoline!
If playing with the tire psi did not help would email Torrie and ask him for his suggestion,with a tune there is more torque on those four wheels,check the front end for play,could be suspension related cause of the increased torque,hp.
