December 02, 2021, 08:21:38 AM
Author Topic:  Front coil/shocks install  (Read 255 times)
Offline Bklynite
  • say hello to my lil friend
  • Jr. Member
  • Miami, Fl.
  • -Given: 3
  • -Received: 8
  • Liked:
  • Likes Given: 0
« on: November 14, 2021, 11:44:59 PM »
Hello, to all.
I've been looking on line but cant find the answer to these two questions, I hope you guys can help me out.
#1 - when reassembling [size=78%] the front coil springs onto the shock how tight does the bolt need to be? is there a specific [/size]lbs.[size=78%] of [/size]torch, or[size=78%] do [/size]I[size=78%] tighten it with the impact gun until the gun reaches its limit?[/size]
[size=78%]#2 - there is an arrow stamp on the top plate, in what direction is it supposed to point? towards the block or pointing outward? [/size]
[size=78%] Thank you for your help.[/size]
[size=78%] [/size]
2011 SHO - Cat deleted,  2.5 Downpipes, K&N air filter, JLT Cath can,  7" cut rear springs
Offline ridered74
  • RotM Winner
  • Sr. Member
  • -Given: 154
  • -Received: 268
    • Ken Kyle Racing
  • Liked:
  • Likes Given: 79
Re: Front coil/shocks install
« Reply #1 on: November 15, 2021, 11:41:05 PM »
I just tightened with impact as tight as it would go.
As for the arrow, I want to say it points towards the engine but I don't remember for sure. The four top bolts will only fit thru the frame in one direction, so if you get all four to peep thru, you have it right. I would use the end link mount point as your frame of reference for lining it up correctly when you put it back on.
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
Offline Ta2dResqr
  • Jr. Member
  • Central Ohio
  • -Given: 0
  • -Received: 10
  • Newb
  • Liked:
  • Likes Given: 39
« Reply #2 on: November 16, 2021, 06:54:50 AM »
#1 - 98 ft-lb
#2 - To maintain wheel camber: position the notch and arrow on the upper strut mount outboard opposite the center of the mounting flanges on the strut.
       To adjust camber +0.5 degrees: position the notch and arrow on the upper strut mount inboard aligned with the center of the mounting flanges on the strut.
Alicia "Sugar Bumps" Hunt 2015 White Platinum Tri-coat Metallic, Livernois Windstorm Cold Air Intake, Livernois Performance Springs, Possible Tune? (3 Bar MAP), MSD Ignition Coils, Drive Bright Puddle Lights, Drive Bright License Plate Lights, FORScan
* Recent Topics
Delivery miners
by emelibtc | November 30, 2021, 03:10:50 PM
ORDER YOUR MINER TODAYAll equipment will be shipped from our warehouse...
Unleashed Cyber Monday Specials
by tmcphail | November 29, 2021, 02:08:51 PM
https://mcusercontent.com/0ca62e20c7302d91c702b3697/images/c990f207-77...
2014 AWD Taurus Police 3.7L - Any Power Adders or Performance Upgrades..?
by irondoor19 | November 29, 2021, 01:54:21 PM
So No More 3.5L Ecoboost for Me, 3.7L V6 in a Very Clean 2014 AWD PI,L...
Re: 2013 Ford Taurus Police Ecoboost For SALE in Columbus Ohio MAKE Offer
by irondoor19 | November 29, 2021, 08:43:38 AM
Sold, Sold, Sold...
Re: I believe I have a bad ABS unit, anyone heard of this?
by LMKS012 | November 28, 2021, 03:19:37 PM
Well, I pulled everything apart on the passenger side rear caliper.&nb...
by Kasin | November 27, 2021, 09:01:02 PM
Finally installed GH intercooler. ...
Re: Black Friday Deals Extended through the weekend.
by Macgyver | November 27, 2021, 05:47:01 PM
Thanks for the sale....
Re: 2013 Explorer Sport died in traffic, cranks no start
by savagefan | November 25, 2021, 09:00:54 PM
I should also add, pending codes p0223Historic codes PO122  PO131...
Re: Unleashed Thanksgiving Specials
by Macgyver | November 25, 2021, 02:52:46 PM
Happy Thanksgiving. Good sale people....
Re: Hello
by Macgyver | November 25, 2021, 02:52:09 PM
Hi and Welcome....
