Swapping a 2018 gen2 3.5tt into a 2012 f150
Started by Stickerslapper2po, September 07, 2021, 09:48:29 AM
Stickerslapper2po
I know it has been done, and i know that there is a fella that did a write up on doing this swap.
I am reaching out hoping one of you can point me into the direction of that post, and or fill me in on the biggest issues that i will run into going this route.
-I would think 1st and foremost is using the 2nd gens pcm and getting it to communicate with the older truck.
- then is it possible to keep the 6 speed( i actually like the trans)
Or does that in it self need to be swapped , then you get into driveline changes and such.
- motor mounts( same different/line-up,  or need adapters,
- intercooler/and  piping, bov would need to be swapped,
- not sure what differences are made between the hose connections to the rad
-also thw vac pump is a different  set up
Currently
2012 f150 platinum screw 4x4
Sct x4
Unleashed Tuning
E70
Variety of dry filters ( aem, k&n, sprectre )
170° stat
M-12405-35t plugs gapped @ .026
Xdi35 hpfp
Dw400lpfp
Snow 2.5 meth kit with the vc-50 controller 80/20 with m1 -625ml/min
Innovate ethanol sensor /gauge
Spd adapters
Spd catted down pipes
Mbrp mid side exit cat back
Powerstop rotors and pads @4 corners
Icon coilovers up front 2.5" up
Bilstien 5160s rear 1.5 up
33x12.5 kenda klever r/ts
20x10 -25 offset toxic wheels
3m volcanic flare / brushed metallic black wrap
Some others things i can't recall
@ 154k miles
I've built this ol' gal up with these chewed up claws of mine over the last 2 years, and as any gearhead would, i have loved ever min. of it.
Gotta get it back up and running asap, considering this is my mobile work station for my graphics co.
Bottom line, is i am trying to determine if it makes more sense to just get a reman2012  and new injectors. ( turbos this spring )
Or, pick up a complete 2018 gen2 and have something unique and a better starting point for building power.
All postive input is greatly appreciated,
I've been in the auto world for the better part of 25yrs.
Not a skill set issue, currently just lacking the approach and the bits and pieces its easy to over look.
2012 platinum f150 4x4 3.55 eloc|33x12.5r20/-25
Sctx-4 5* 87-93 tunes|Unl. 93/e30 tunes
Dw400 lpfp / aem filter /modified airbox
Icon 2.5 coilovers front/bilstein 5160s rear.
Macgyver
I would stick with a 2012 motor since you are not hauling etc.
Side by side if you could race your 2 truck builds. Would all the extra work done to convert to a 2018 motor be worth it for a few truck lengths on a drag strip per say ? It sounds like a lot of work.
Stickerslapper2po
Sorta ,
But even tho I do like tonrun this thing hard,
The 2nd gen motors have a lot more going for them than the 1st gen.
Dual fueling , larger turbos,  better head flow, and a hand full of others that  I cant think of at the moment.
But on the other hand you arent wrong either,
If my heads arent toast, then a built rmb short block might be the best route and I'll stick to direct port meth for extra fuel.
Coyote Chaser
Sounds like an awesome project! Keep us posted on your progress!!
2014 Fusion Titanium 2.0T
2018 Mustang Ecoboost
