Well, i got more of a response from another forum, so I will just cut and paste my ending post to my issue...
".........Now, I would ask that this thread be deleted, but it may help someone else out.. I played the Stupid Game and won the Stupid Prize. The Forscan programming works as it should.
HOWEVER, if you leave your 2nd key inside the vehicle and open and close the rear hatch while your vehicle is locked, it will give you the dreaded two horn honk after it closes. In my original post, I had my backpack in my vehicle which had my 2nd key.
So yes, laugh at my expense..LOL.
Just completed the following..
Test 1) without key in vehicle - engine running[/b], exit vehicle, lock doors. Open and close rear hatch.
Results: NO two horn honk.
Test 2) with 2nd key in vehicle - engine running, exit vehicle, lock doors. Open and close rear hatch.
Test 3) without key in vehicle - engine not running[/b], exit vehicle, lock door. Open and close rear hatch.
And we all know Test 4, which is what I went through.
All four tests were conducted twice. Once where I locked the vehicle and did not wait for the interior lights to dim and then waiting for the interior lights to dim.
Lesson for the day: The Forscan programming to disable the two horn honk will give you the two horn honk for the rear hatch, ONLY if you have the 2nd key in the vehicle and the engine is NOT running."
