May 21, 2022, 02:00:00 AM
Todays Posts
Featured Topics
Recent Posts
Classifieds
Help
Search all of EBPF
Vehicle Specific Boards
Taurus SHO, Taurus PI, and MKS
Maintenance and Troubleshooting
Random Pull/Torque Steer after new moog lower control arms.
2
Likes
« previous
next »
Pages:
Author
Topic: Random Pull/Torque Steer after new moog lower control arms. (Read 7272 times)
mystery101
Full Member
Port Orange, FL
Thank You
-Given: 1
-Received: 2
Ecobooster
Liked:
Likes Given: 0
Re: Random Pull/Torque Steer after new moog lower control arms.
Reply #15 on:
December 30, 2021, 11:42:11 PM »
2016 SHO- Ruby Red - Performance Pack (Mods: 170*F Thermostat, 3Bar Map, NGK .28 colder plugs, JLT PCV catch can, OBX downpipes, GEARHEAD e30 tune!)
xartic1
Full Member
Thank You
-Given: 3
-Received: 20
Twin Turbskies
Liked:
Likes Given: 0
Reply #16 on:
December 31, 2021, 10:44:19 PM »
Quote from: mystery101 on December 30, 2021, 11:42:11 PM
Sweet, still looks like Tapatalk hasn’t figured out this issue with replies.
What I stated was something along the lines of that my vibration issue was due to the knuckle bushing on the rear where the control arm connects to. Completely worn out and I replaced it with a Moog bushing since I don’t really have faith in Dorman. I would love to swap the knuckle bushing with a poly along with the front control arms for more rigidity and for long term durability.
I replace almost all my bushings in my Ex with new parts since they aren’t that expensive but having 120K miles on the vehicle just gives me a piece of mind while hitting some turns pretty hard.
Last Edit: December 31, 2021, 10:47:53 PM by xartic1
2014 Explorer Sport - Livernois 91 tune, 3 Bar MAP, Bilstein B6's, Dicunzolo Transmission Mounts, Mishimoto J-Line FMIC, AEM Drop In Filter, Steeda Rear Sway Bar, PPE Engineering Catless Downpipes, Reische 170 T-stat
2011 Mustang GT Brembo - Bama 91 tune, Steeda Intake, LTH, 3" full exhaust with O/R X-Pipe no resonator, every possible suspension component replaced, weighs 3505 with 1/4 gas
hawkeye93
Sr. Member
Lakeville, MN
Thank You
-Given: 99
-Received: 208
Liked:
Likes Given: 0
Reply #17 on:
January 02, 2022, 07:40:58 PM »
I also replaced my LCA with Moog. The Moog arms do not use a castle nut, and I have had an issue with the ball joint loosening. You can't get a socket on the nut; you need to use a crowfoot wrench, and it can be difficult to get the necessary torque on the ball joint nut.
2015 Ford Taurus SHO PP
12.219@112.84
PPE catless DP, Gearhead IC, SP-534, Reische 170, 3 bar, hybrid meth system, tunes from Unleashed, Livernois, Brew City Boost & AJP
1965 Ford Mustang Convertible 289 4V/T5Z/3.55
1955 Ford Fairlane Club Sedan 272 4V/Fordomatic
mystery101
Full Member
Port Orange, FL
Thank You
-Given: 1
-Received: 2
Ecobooster
Liked:
Likes Given: 0
Reply #18 on:
January 19, 2022, 10:26:36 AM »
On the moogs. I tightened them down as tight as they would go. You shouldn't need a crowsfoot. I did it with a 11mm on the stud and a long wrench. However my issue was not caused by loose ball joints. The moog lcas came with subpar forward bushings from factory without metal spacers and no matter how tight you go with the bolt the bushing barely contacts the frame and allows too much lateral movement.
Pages:
« previous
next »
