August 02, 2021, 05:51:15 AM
Author Topic:  Any advice on how to improve 1/4 mile times?  (Read 449 times)
Offline CTurbos
  • Newbie
  • Michigan
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 2
« on: July 17, 2021, 07:03:15 PM »
Hey everyone, i'll start off that i'm new to the forum and came here hoping maybe some of you could help me figure out what i am missing here. My car is a 2011 non pp, i saved it from a consignment auction and gave her a new home. Since I have replaced the engine due to the fact it had jumped time before i had purchased it. I then tuned the car, added gearhead turbos, intercooler, xdi 35, stainless works catless dps, AD mounts, EPP intake, and MSD coils. the car is tuned on e30 at the moment and i cant seem to get a dragy better then 13.49 in the 1/4 mile. I typically brake boost around 2000-2200 rpm. I have some all season pirellis on at the moment and i wonder if that may be whats holding me up. When i tracked the car before i had recieved my xdi 35, running only 93 oct pump gas i managed to make a pass of 13.37 at the track. In the Logs everything seems to be doing ok. The car is full weight but I just feel like i'm running tune only times here, or even stock when the car is far from it. The time has to be getting lost somewhere
« Last Edit: July 18, 2021, 10:02:15 PM by CTurbos »
2011 Ford Taurus SHO| Gearhead Turbos| Gearhead Intercooler| Stainless Works Catless Downpipes| XDI-35| AD Mounts| E30 GH Tune| EPP Intake|
Offline ridered74
  • RotM Winner
  • Sr. Member
  • -Given: 154
  • -Received: 263
    • Ken Kyle Racing
  • Liked:
  • Likes Given: 72
Re: Any advice on how to improve 1/4 mile times?
« Reply #1 on: July 18, 2021, 04:36:19 AM »
You're definitely losing all your time in the first 1/8 mile. I'm usually at 91-92 mph at the 1/8, so you're a good bit slower there. I have same mods other than I'm on stock turbos. What psi are your tires at?
What does dragy show your 0-60 time as?
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
Offline Macgyver
  • Super Moderator
  • Reading, Pa.......
  • -Given: 100
  • -Received: 387
  • Liked:
  • Likes Given: 23
« Reply #2 on: July 18, 2021, 03:09:27 PM »
Launching the yacht is what helps. 60 foot is where you are losing time. Most get 1.7-1.9. Lowish tire pressure around 26psi depending on the rubber you have.
I would also say the tune. My 2015 SHO was a friggin BEAST with an AJP Turbo E30 tune. Never tracked it tho. Pulled like a freight train above 60mph (3rd gear). So much better than 93 or OEM.
Offline CTurbos
  • Newbie
  • Michigan
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 2
« Reply #3 on: July 18, 2021, 09:55:30 PM »
I appreciate your guys replies, i have both GH and Ortiz tunes. Lately i have been running just the gearhead because my car seems to like it better so that's what i started logging with first. Looks like im close to 10-12 mph slower then you in the 1/8 holy cow! 8.77 1/8th on dragy with 2.10 60ft. Tire pressure is 28 psi all around on the streets. Got a tip from a vet ecoboost enthusiast that he only saw improvement in tire psi at the track of 23 in the front 28 in the rear. So that's what i run on the track. I'm not really blowing the wheels off when im launching either other then a little chirp so im not entirely sure if its an issue with it hooking, for some reason it just feels like its not pulling out like it should be off the launch, i'm wondering if the stock tq converter can't handle the power thats getting put to it.
Offline Macgyver
  • Super Moderator
  • -Given: 100
  • -Received: 387
  • Liked:
  • Likes Given: 23
« Reply #4 on: July 19, 2021, 08:56:58 PM »
Are they stock tunes per say or have you data logged and had multiple revisions ?
Your numbers are not much better than an OEM car. You should be in the very low 12's imho depending on the DA and track conditions.
Offline ridered74
  • RotM Winner
  • Sr. Member
  • -Given: 154
  • -Received: 263
    • Ken Kyle Racing
  • Liked:
  • Likes Given: 72
« Reply #5 on: July 20, 2021, 01:20:55 AM »
Agreed...even if your tires are absolute crap you should still be able to hit 12's easily. I can launch from idle and not lose more than a tenth or two off my time.
If you haven't already sent Matt a log that's the first thing I would do. I'd send him a pic of the time slip too.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
* Recent Topics
ecoboost_xsport Consolidated Build/Maintenance Thread
by Ecoboost_xsport | July 30, 2021, 08:24:58 PM
Even though I haven't been posting as frequently lately (YouTube ...
Re: 15 Interceptor Sedan Ecoboost with GHT Tune - Engine Coolant Overtemp
by SHOdded | July 30, 2021, 02:58:41 PM
on the 2.7, ford says to replace the ECT sensor and/or the knock senso...
Re: Random Pull/Torque Steer after new moog lower control arms.
by SHOdded | July 30, 2021, 02:54:07 PM
have an independent service shop verify your work with the LCAs. ...
by SHOdded | July 30, 2021, 02:49:20 PM
https://www.ecoboostperformanceforum.com/index.php/topic,1239.0.html...
Boost / Vacuum Source
by Ecoboost_xsport | July 29, 2021, 12:36:21 PM
Those of you wondering where a decent place to tap into a boost/vacuum...
Re: New from Minnesota...
by PDSHO | July 27, 2021, 04:15:43 PM
Re: Ol' Guy in New England........
by PDSHO | July 27, 2021, 04:13:04 PM
Re: Terrain Management System Fault - wrench light
by EcoHell | July 22, 2021, 09:21:04 PM
Yes and this was on a 2015 SHO. She sat 3 days if I recall. Fri Sat S...
Re: Part numbers needed for rocker panel retainers...
by 6500rpm | July 11, 2021, 05:41:29 PM
Results-...
FREE Goody Bag Swag for Your Car Show
by RockAuto | July 08, 2021, 04:08:40 PM
RockAuto would love to work with your upcoming car show, cruise-in, sw...
