- Full Member
- Newb
- Logged
When was the last time coolant was changed? It does break down over time. You may also want to consider a coolant additive (such as Water Wetter, Purple Ice, etc). Installing a lower temperature thermostat or adjusting fan temps (within the tune) may help. Lastly, I would start looking at methods to contain or eliminate heat. Wrapping exhaust components or coolant pipes to lower underhood temperatures. Adding hood vents (true functional products). Methanol injection. Adding trans or PTU coolers. Everywhere you can lower temp will lower over all heat and allow the system to last longer before you have issues.
Lucy Ford 2015 Ruby Red Tinted Clearcoat Metallic, GearHead AO Performance Tuned - SCT X4, GearHead Intercooler, 3-Bar MAP, EPP Hot Pipes (Plum Crazy), EPP Dual Intake (Plum Crazy), AD Mounts, MSD Coils, JLT Oil Separator, 160 Thermostat, Ortiz Performance Battery Hold Down (Plum Crazy), Hellcat LPFP, 255/45R20 DSW06 Plus, Sync3 Conversion, CYANLabs Syn3, FMods, Jail Broke APIM, Infinity Kappa Speakers, Speaker Baffles, Whelen POV Response Package - (Inner Edge FST, Inner Edge RST, Sidekick, Tracer, LINV2, IONV3, HHS 200W, Howler 200W), Z-Flash, Full LED Swap, Drive Bright DRL Kit, Drive Bright Puddle Light Kit, Ford Sunroof Visor, Window Chrome Delete, OSRAM XENARC Night Breaker Laser, FORScan, OBDLink, Ford Cargo Organizer
