June 23, 2021, 01:13:52 PM
Author Topic:  2014 MKS ignition coils?  (Read 831 times)
Offline Speedydog5
  • Newbie
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 0
« on: April 15, 2021, 04:47:02 PM »
Was going to change plugs but might as well change coils what is a good brand to go with  besides Motorcraft and where is cheapest vendor
Offline TopherSho
  • Eugene Oregon
  • -Given: 504
  • -Received: 411
  • 1st boosted rig!
  • Liked:
  • Likes Given: 5
Re: 2014 MKS ignition coils?
« Reply #1 on: April 16, 2021, 09:37:05 AM »
In my experience with the 2010 SHO,  the MSD coils did not make any difference after about 5k miles.   It idled smoother but saw no gains on a moderate MET tune running 22/23 degrees timing on 14.5 boost from AJP.  The do look pretty though :D
Best 0-60 public road 4.35s
Offline avidmotion
  • Sr. Member
  • -Given: 5
  • -Received: 91
  • Liked:
  • Likes Given: 2
« Reply #2 on: April 16, 2021, 10:00:37 AM »
I like MSD, smoothed out idle and got rid of a slight studder mid throttle. So fsr so good, 8000 miles on new set...
Sp542@.028, windstorm CAI, MSD coils, AO GH TUNE, GH intercooler, All Amsoil, General Gmax-rs summer tires, +PP, PP PADS,EDC rotors, Colinite 476s wax, used PPE DPs, Resonator | 3rd Cat Delete with custom X pipe, Dicunzolo Gen2 Trans Mounts|, 3 bar, stock thermostat,  TRACY LEWIS DESIGNED Team RXP, the Original oil separator.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4244
  • Liked:
  • Likes Given: 13
« Reply #3 on: April 22, 2021, 05:36:02 PM »
MSD is the only brand that has been tried with some degree of success.  OEM is still the optimal way to go.
Offline Ta2dResqr
  • Jr. Member
  • Central Ohio
  • -Given: 0
  • -Received: 8
  • Newb
  • Liked:
  • Likes Given: 34
« Reply #4 on: May 03, 2021, 08:31:01 AM »
I love my MSD coils. Keep an eye out on Amazon for a "used" set. They are usually a return item that did not fit or was unwanted. My set had part of the packaging cut off but was brand new, never installed. There is a set of 6 for $97.24 as I type this. MSRP on an OEM coil is $109.99 each. 6 for less than 1 is a win all day long in my book.
Alicia "Sugar Bumps" Hunt 2015 White Platinum Tri-coat Metallic, Livernois Windstorm Cold Air Intake, Livernois Performance Springs, Possible Tune? (3 Bar MAP), MSD Ignition Coils, Drive Bright Puddle Lights, Drive Bright License Plate Lights, FORScan
* Recent Topics
Re: Verdict : Torrington bearing on the way out.
by Admin | Today at 07:30:00 AM
*final update on this thread*Finally figured out what made the last tr...
Re: Datalogging with SCTx4 Device
by ridered74 | Today at 12:23:20 AM
Thanks for this amazing write up. I'll be doing this today to sen...
by Scott13SHO | June 21, 2021, 08:03:06 PM
I sold my SHO today to Carvana.Why Carvana ?Why not? I havenít been dr...
Re: PPE catted downpipes missing 02 sensor bung
by Macgyver | June 20, 2021, 12:05:51 PM
Wow, the price has really gone up... but so has everything else.Had tw...
Re: "Complete" List of TSB's for your 2010-2012 SHO
by rdmccrary | June 18, 2021, 08:55:54 AM
TSB 10-22-4 AWD VEHICLES - SHUDDER-CHATTER-VIBRATION ON TURNS OR THUMP...
Re: Picked up an 18 Navigator
by jims2015 | June 18, 2021, 08:46:52 AM
So you dont get the $7500 off the sticker then ?Nope, you take it off ...
Re: Factory fuel pump specs
by Macgyver | June 17, 2021, 08:17:35 PM
Yeah but then you should need a LPFP to feed it and will it run off th...
Re: RockAuto.com Discount Code - Expires July 5, 2021
by Broodingrage | June 16, 2021, 07:33:54 AM
This vendor saved my wallet when I had to replace my 2013 MKS Dynamic ...
Re: Engine Fans start immediately Mks
by Matt_Sommers | June 15, 2021, 07:59:40 PM
Is the AC on? If yes, then the fans are supposed to be running.I didn&...
Re: 2010 ford sho blue smoke on decel
by 6500rpm | June 15, 2021, 04:37:07 PM
I  just ran my car in Oasis last week and was reading through TSB...
