Engine shield under the front busted bolts .. safe to drive in rain????
Started by TopherSho, March 19, 2021, 05:25:57 PM
TopherSho
So the twist clips have all busted off my Ford Taurus lower engine shield,  the giant plastic skip guard looking piece.   It is still raining a crap ton,  so all the electronics underneath,  o2's some other sensors and connectors that normally would be hot and dry will know be hot and wet .. splashed on in 3-4 inch deep puddles..
safe?  get replacement before fording Oregon puddles ????
Best 0-60 public road 4.35s
Sbouvia
Well I didn't realize Ford never put mine back on when I had an oil change done when still under warranty and then wondered why oil changes were so damn easy once I started doing them myself after warranty expired. I easily put on 40,000+ miles before I bought a new one from Tasca.
~Scott
2013 SHO non-pp. Powerstop Top Cop kit rotors and stock Akebono Ceramic Pads, 3bar map sensor, 93 octane 3bar AJPTurbo tuned, but not dialed in.
2002 Jeep Wrangler TJ (Jane) w/ 2.5" lift, Banks torque tubes, monster exhaust and intake.
1991 F Super Duty 2.5 ton dump truck w/ 7.3IDI
BlueSHO
Quote from: Sbouvia on March 19, 2021, 09:32:18 PM
Part number?
Sent from my SM-G950U using Tapatalk
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
Sbouvia
Technically it's the rear deflector which is DA8Z-9910494-A. It comes loaded with screws. The twist clips and little bushings are listed below. I didn't realize the rear deflector came loaded so I bought it all and then sent back what was not needed. All my clips were still intact.
[/size][/color]
~Scott
TopherSho
BlueSHO
Quote from: Sbouvia on March 22, 2021, 06:13:11 PM
[/size][/color]
Thanks Sbouvia
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
TopherSho
Note > you do not get the HC1 INSERTS that the screws , erm screw into.  They are a sperate cost.  6$ each >:(  .... but ordered, ~le.sigh
BlueSHO
Quote from: TopherSho on March 23, 2021, 01:21:02 PM
HC1 inserts?
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
TopherSho
Quote from: BlueSHO on March 24, 2021, 02:12:19 AM
HC1 inserts?
Disregard!   W709367S439 covers it... you are correct.
Sbouvia
The only thing that doesn't come is the clips that are actually in the body of the car. So if those are rusted or broken you will need to order those. I think those are the -W716006-S439 part number which is 17 in the part diagram. When I look up the clips you mentioned they state grill clips, I didn't see any of those are part of the under shield.
~Scott
