Started by Gray Brick, November 07, 2020, 06:03:17 PM
Quote from: Gray Brick on November 07, 2020, 06:03:17 PMInstalled upgraded Deatschwerks and car stumbles at light load. idle and under 20% throttle while driving the Flex runs fantastic.No leaks in intake or associated items... did pressure test.What gives? Any suggestions?Thank you.
Quote from: Gray Brick on November 10, 2020, 01:47:59 AMTune was adjusted for them.I will check the HPFP tomorrow.Engine runs perfect in each gear until 20%+ throttle.
