October 20, 2020, 10:38:50 AM
Author Topic:  Highest Dyno on Stock turbos  (Read 494 times)
Offline GotGrip?
  • Conversation Ruiner
  • Jr. Member
  • Minnesota
  • -Given: 14
  • -Received: 37
  • Liked:
  • Likes Given: 10
« on: September 09, 2020, 05:11:42 PM »
Just curious if anyone knows the HP limits of stock turbos. Assume you're FOB, E30, but no meth or no2. Has anyone ever hit 500whp like that?
Sorry if this had been asked before, been searching all day and haven't seen it.
2016 SHO Non-PP, GH/AJP E30 Tune,3Bar MAP, K&N Typoon, EPP Noisemaker Delete, H&R Springs, ZEDD SL5 19x9.5, PS Drilled/Slotted rotors, TreadStone TR8C FMIC, SSM Trans Mounts, TCE Custom Catted DPs, FMIC Sprayer, XDI35
Offline StealBlueSHO
  • Administrator
  • -Given: 2885
  • -Received: 2828
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
Re: Highest Dyno on Stock turbos
« Reply #1 on: September 09, 2020, 06:55:01 PM »
I haven’t seen it. Mid 400’s with an intercooler, fuel, and E30..
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
Offline 76fomoco
  • Full Member
  • Nampa, ID
  • -Given: 77
  • -Received: 146
  • Rabbit Hole master
  • Liked:
  • Likes Given: 2
« Reply #2 on: September 09, 2020, 07:22:14 PM »
to get past the mid 400 you need the GH turbos
2013 PP AJP, 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 5-16-2020  12.40 with 3850 before GH turbos
DA trap best 116.79
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
  • Administrator
  • -Given: 2885
  • -Received: 2828
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #3 on: September 09, 2020, 07:23:02 PM »
Or ATPs or anything bigger than the mini-muffins we currently get stock.
Offline bamsho
  • south williamsport, pa
  • -Given: 236
  • -Received: 540
  • Liked:
  • Likes Given: 30
« Reply #4 on: September 09, 2020, 07:44:25 PM »
I'm at 419 no meth, 427 with meth on the stock huffers.
Offline GotGrip?
  • Jr. Member
  • Minnesota
  • -Given: 14
  • -Received: 37
  • Liked:
  • Likes Given: 10
« Reply #5 on: September 09, 2020, 08:48:56 PM »
Yeah I was @ 421/503 prior to getting DPs or a revision for the IC. I'm think now that I've raised the boost, added DPs I think I've got to be close to 450-460whp. I have a few more things I want to try, but I think my ultimate goal is to hit that 500 mark before turbos even if that means throwing no2 at it, though I would prefer not too. Trying to get another dyno run set up to see how much of a gap I need to close but will post up another thread when I get to that.
  • Administrator
  • -Given: 2885
  • -Received: 2828
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #6 on: September 09, 2020, 08:50:27 PM »
Sweet! Make sure to post up the results!
Offline 802SHO
  • Currently World’s Fastest Ecoboost SHO
  • RotM Winner
  • Essex Junction Vermont
  • -Given: 2383
  • -Received: 1146
  • Boosted
  • Liked:
  • Likes Given: 0
« Reply #7 on: September 11, 2020, 07:39:23 PM »
NOS!!!!!
  • Administrator
  • -Given: 2885
  • -Received: 2828
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #8 on: September 11, 2020, 07:39:47 PM »
NOS!!!!!
Lol!!
Offline ddlopes
  • Sr. Member
  • -Given: 4
  • -Received: 87
  • Liked:
  • Likes Given: 0
« Reply #9 on: September 16, 2020, 09:56:31 PM »
I’ve put down 433whp on stock turbos running E30 tune with meth.
2013 SHO P/P mods: EcoPower Parts dual CAI, 3 bar, PPE catted down pipe, SCT X4, 170 degree thermostat, SNOW PERFORMANCE methanol stage 3 with ProMeth staineless steel braided lines, AeroForce gauges, Hot pipes, custom boost activated cutout xpipe, tial bov, Tial Wastegate mod, GH intercooler, MSD coils, AFE throttle spacer, UPR catch can, Rovos Durban wheels, AJP tuned to 389hp and 503trq on mustang dyno
Offline GotGrip?
  • Jr. Member
  • Minnesota
  • -Given: 14
  • -Received: 37
  • Liked:
  • Likes Given: 10
« Reply #10 on: September 24, 2020, 12:03:44 PM »
NOS!!!!!
I'm not saying a 50 shot is out of the question >.>
* Recent Topics
2010 SHO PP Loop Track Mods
by ticoscen | Today at 10:08:51 AM
Hey there. I'm tracking my SHO PP 2010 in the mid atlantic area o...
P0442 Small Evap Leak Code
by SHO-Pa | Today at 09:48:34 AM
I did a search and came up empty on this one. On my 2011 SHO I am gett...
Re: Can't find a couple of modules in Forscan
by Black Dream | October 19, 2020, 06:11:38 PM
So I learned a few things over the last week. Talked to AdmiralSparkle...
Re: Need to share with this group.
by bamsho | October 19, 2020, 01:16:22 PM
Im not running away from this, I feel better if it's out in the o...
by bubbarotondo21 | October 19, 2020, 10:21:14 AM
Finally got my muffler delete done, still have stock resonator and cat...
by MiWiAu | October 18, 2020, 02:00:41 PM
Hiya, folks! Just checking in!Got my winter wheels installed yesterday...
Re: SCT Livewire Killed PCM
by ridered74 | October 18, 2020, 01:06:30 PM
I've heard of several people having issues flashing vehicles for ...
by bpd1151 | October 17, 2020, 10:44:01 PM
PRICELESS!!Sent from my SM-N950U using Tapatalk...
by StealBlueSho | October 17, 2020, 03:01:45 PM
Out with the AD front mount and in with the stock one.. Being as I’m t...
Re: Tail lights
by Nova | October 16, 2020, 09:43:25 PM
Know how FMC sources parts from their vendors....I will simply guess t...
