September 19, 2020, 05:23:38 AM
Author Topic:  HOW-TO: Change plugs / Trying out Brisk spark plugs  (Read 152 times)
Offline Ecoboost_xsport
  • 2015 Ford Explorer Sport
  • Full Member
  • Orangevale, CA
  • -Given: 40
  • -Received: 52
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« on: September 08, 2020, 03:26:44 AM »
This is sort of a how-to on how I do my plug changes as well as getting away from the FoMoCo SP-542 and trying out a different plug.  It remains to be seen how well it will work out for me, but I will definitely keep you guys updated.
So on the advice of a pretty good local tuner, I decide to try out some Brisk spark plugs (https://www.briskusa.com/).  There wasn't necessarily anything wrong with the 542s I was running, but with the power goals and modifications I am shooting for, I wanted to attempt one additional step colder of a plug (OEM was 534s, heat range 6, 542s are range 7) by going heat range 8 to see if I can squeeze some timing out of her.  Although I have limited personal experience with Brisk, a lot of top shops and tuners use these things.  I did some research and on the advice of that local tuner, decided on trying out the Silver Racing plugs (hey, it has Racing in the name, so it MUST be good, lol).  They are heat range 8, which is 2 steps colder than OEM and it remains to be seen if I can get a bit more timing out of these or if they will just foul out.  Oh, and they are Made in the USA so that's a plus, right?
First thing is getting those connectors off the coils.  Slide back the red clip on the coil connector, it's easy enough with a small flat head screwdriver:
Then just press the clip retainer and slide off the connector.  After disconnecting that, use an 8mm socket to remove the coil retaining bolt, then pull out the coil. Even though I only complete one cylinder at a time so as not to confuse things, I still typically mark the coil with a sharpie identifying which cylinder it came from.
Before you take out the old plug, it is important to use some air to blow out any debris that may be residing in that spark plug well so that it doesn't fall into the cylinder.  You'd be surprised how much junk gets blown out of there, despite them being "sealed".
After pulling out the old spark plug, I look at the condition of it, mark it with a sharpie as well and I personally keep my old plugs for at least until the next plug change to compare them to the previous set.  So they go in a zip lock an stored away for awhile.
Anyway, here's the new plugs:
Side-by-side comparison of the plugs:
Tip design difference:
Onto gapping the new plugs.  I had the 542s gapped to 0.26 and went with the same on the Brisk plugs.
I use an old piece of rubber hose to put onto the end of the new plug as it makes it a bit easier to install by hand into the well. But before I install it, I give it a good thin coating of some anti-seize.  You will thank yourself later if you do this, trust me.
Factory Service Manual says torque to 133 in-lbs, not much, I know.
If you convert the in-lbs to ft-lbs you get 11.1.  Comparing to the recommendation provided by Brisk, it falls right in line (the plugs are conical seat, 14mm thread diameter going into an aluminum head).
After installing the plug, make sure to use a small amount of dielectric grease inside the coil to help keep moisture out as well as ensuring it doesn't adhere to the plug and become a nightmare to remove for the next plug change.  In the photo showing how much is coming out of the tube is the amount I usually use.
After that, installation is the opposite of removal.
Some tips to be mindful of:
1)  If you have the composite valve covers like I do, be very careful when torquing the coil retaining bolt.  The threaded hole is just a metal insert that can spin on you if over-torqued.  If you spin it too badly, that's it...I don't really know of a fix other than getting a whole new valve cover, maybe some sort of epoxy.  The book says 62 in-lbs, then another 50 degrees, but TBH, I did that spec on one of my retaining bolts the last time I changed the plugs and it began to spin (yes, I checked to make sure I was in-lbs and not ft-lbs).  So before I let it get too bad, I just left it.  Luckily it was in pretty tight and didn't have any issues the entire time I had those 542s in.  This time around I was just very careful to do it by hand and get them as tight as I felt comfortable. That seemed to work pretty well as they are all solidly in there.
2)  If you have an XDI HPFP, you're going to have to remove the low and high side fuel lines as well as the top 2 bolts to spin it a bit to access the coil on cylinder 4.  I think I heard XDI had a redesign, but can't confirm that.
Anyway, as mentioned, I'll keep you folks updated once I get her back on the road.  After doing some research on the Brisk product line, I gotta say, I'm fairly impressed so far.  Now the proof will be when I get some miles on 'em.
« Last Edit: September 08, 2020, 10:49:15 AM by Ecoboost_xsport »
IG: ecoboost_xsport
Airaid CAI | ATP +2 Garret Turbo Upgrade | Big Head Motorsports Catless Turbo-Back Exhaust | MSD Ignition Coils | XDI-60 HPFP | FoMoCo 3bar MAP | DeatschWerks DW300c LPFP | UPR Catch Can |  AD Gen 2 Torque Mounts | Braille i25X Lithium Battery | Brisk Silver Racing RR12YS Plugs (0.26 Gap) | EPP Hot Pipes | Tial Sport QR 50mm VTA BOV | 160į Livernois Thermostat | H&R Super Sport Lowering Springs | Wilwood 15.00" Front Rotors  | Wilwood 14.25" Rear Rotor | Wilwood W4A Front & Rear Calipers | Advan GT Premium Wheels 20x11-15mm | Hankook Ventus ST RH06 295/45-20 | Bilstein B6 Front Struts | Bilstein B6 Rear Shocks | Steeda Rear Sway Bar | Steeda Rear Toe Links | Steeda Rear Trailing Arm | SPC Front & Rear Camber Adjustment Bolts | Innovate Motorsports MTX-D Ethanol Content Gauge w/GM 13577429 Flex Fuel Sensor | Redline Tuning Hood Struts | FoMoCo PI Rear X-Brace | Diode Dynamics SS3 Pro Yellow LED Foglights | Custom RaceSeng Front Tow Hook | WR: 3rd Row Seat Removed | SCT Livewire TS+ | 100 OCT AJPTurbo Tune
Offline Macgyver
  • Super Moderator
  • Reading, Pa.......
  • -Given: 99
  • -Received: 354
  • Liked:
  • Likes Given: 5
Re: HOW-TO: Change plugs / Trying out Brisk spark plugs
« Reply #1 on: September 08, 2020, 02:55:52 PM »
What type of electrode is it in this plug. They show all different types.
I hope the plug works better than the website. I am getting all sorts of web errors. Edge. Chrome. Opera browsers.
« Last Edit: September 08, 2020, 02:59:45 PM by Macgyver »
  • Full Member
  • Orangevale, CA
  • -Given: 40
  • -Received: 52
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #2 on: September 08, 2020, 04:11:17 PM »
Lol, hmm works fine on my end. Electrode is silver. Its their Silver line. They do have a lot of different options for lots of different needs.
Sent from my SM-G965U1 using Tapatalk
IG: ecoboost_xsport
Offline StealBlueSHO
  • Administrator
  • -Given: 2822
  • -Received: 2798
  • I poke at BPD1151
  • Liked:
  • Likes Given: 40
« Reply #3 on: September 08, 2020, 10:19:09 PM »
Fantastic write up!!!! And 100% yes on the dielectric grease, every time, it wonít hurt nothing. The anti seize is a holy war Iím not getting into.. Iíll leave it that yes, I agree with you.
Note on the fuel pump...
It is MUCH easier to just remove the -6an male low side connector on the pump vs removing both lines, bolts , and spinning.
So remove the low side fuel line, use a 17mm iirc wrench, and unscrew the adapter from the pump. Take no time at all  and will let you get the number 4 plug/coil out.
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
  • Full Member
  • Orangevale, CA
  • -Given: 40
  • -Received: 52
  • Mad Scientist
    • The Workshop
  • Liked:
  • Likes Given: 0
« Reply #4 on: September 08, 2020, 10:22:14 PM »
Ah....very nice catch. I will try that next time! I wasn't sure if there was some sort of spring or ball valve or something behind it that could fall out and be a nightmare to assemble again. But good call...
« Last Edit: September 08, 2020, 10:32:56 PM by Ecoboost_xsport »
IG: ecoboost_xsport
* Recent Topics
Re: GearHead torque converter anyone use it??
by xartic1 | Today at 12:57:02 AM
Anyone have a link to these?...
Re: SM105K's Ownership/Performance/Maintenance Thread
by sm105k | September 18, 2020, 12:00:36 PM
I ventured into Intercooler cooling lol.  Bought this off Amazon....
Re: New Member From Illinois -15 SHO
by ATJ8 | September 18, 2020, 10:14:52 AM
Thanks! Its getting there. Next step is intercooler, hpfp and meth. I ...
Re: And the award for most frequently broken car goes to...
by MKS Tom | September 18, 2020, 09:41:22 AM
As someone who snapped his PTU in half myself .. Quick Question .. Are...
Re: Blocking of Vendors.....
by bpd1151 | September 17, 2020, 11:58:22 PM
Likewise. Sent from my SM-N950U using Tapatalk...
Re: MIR Private Rental 09/23/2020
by bamsho | September 17, 2020, 05:50:17 PM
I'm in, just waiting for my invite....
Re: Ride of The Month September 2020!!!
by sm105k | September 17, 2020, 01:53:07 PM
Half way through the month for voting!  Post your rides up and le...
Re: Ecoboost Bronco!!
by limited02 | September 17, 2020, 10:46:51 AM
The 2.7 is now slouch for sure, but geezuz, that's asking an awfu...
by ZSHO | September 17, 2020, 08:09:15 AM
STELLAR Quality Craftmanship @ its finest Bpd1151!  :)  Bore...
Re: Highest Dyno on Stock turbos
by ddlopes | September 16, 2020, 09:56:31 PM
Iíve put down 433whp on stock turbos running E30 tune with meth....
