June 01, 2023, 01:27:27 AM
Author Topic:  Looks like another unhappy customer  (Read 7763 times)
Offline bpd1151
  • Forum Supporters
  • Elite Member
  • SHOcago S/W 'Burbs
  • Thank You
  • -Given: 2611
  • -Received: 2679
  • SHOGAZM
  • Liked:
  • Likes Given: 0
Re: Looks like another unhappy customer
« Reply #15 on: September 14, 2020, 09:28:05 PM »
That craptastic 'L' company sure is building a reputation for itself.
My God.
Offline SM105K
  • IG @fafomotorsports
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 1049
  • -Received: 1224
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 31
« Reply #16 on: September 15, 2020, 01:47:28 PM »
Damn!  LMS should become a music label company now.  Seems Dan could be a damn good producer!  THE HITS JUST KEEP ON COMING!  Across all platforms/genres too.
« Last Edit: September 15, 2020, 01:55:37 PM by SM105K »
* Recent Topics
Re: 1st time owner
by SHOdded | May 15, 2023, 04:39:13 PM
nice ride, nice wheels. welcome and congrats!...
Re: New Member from Cincy
by PDSHO | May 14, 2023, 09:34:42 PM
Greetings from Nebraska.Also Go Bengals!Greg...
Re: White Smoke, Shuddering on brand new turbos
by jordanc67 | May 09, 2023, 12:54:12 PM
idk if this is the case here but apparently white smoke can also be ca...
Re: New 3 bar MAP - Now engine surges and multiple dash error lights
by SHOdded | May 08, 2023, 06:30:31 PM
if you replaced the 2 bar map with a 3 bar and did not tune for it, th...
Re: 3rd cat & resonator delete feedback
by kryptto | May 08, 2023, 05:27:41 PM
Do you mind sharing the part number ofDescriptions.  Or should I ...
Re: BOV - truths - education
by kryptto | May 08, 2023, 05:12:46 PM
Hey all, just an update and I am sure it won't be a surprise.&nbs...
Ford Taurus Sho makes grinding noise
by Mnelson | May 08, 2023, 11:11:49 AM
My ford Taurus sho usually makes a grinding noise when the tires spin....
Re: RockAuto.com Discount Code - Expires October 5, 2022
by SHOdded | May 06, 2023, 04:25:00 AM
idk if rockauto is still monitoring this site. but in the meantime, go...
Re: Piggy back vs flash tune. Which is best?
by Macgyver | May 03, 2023, 02:00:29 PM
Non E 91 is a good choice.5000 ft is tough on turbo output but the tun...
Re: UPR catch can kit
by Macgyver | May 03, 2023, 01:58:56 PM
Ford OEM rotors are bad. Same issues with the Edge ST. PP rotors are b...
