November 24, 2020, 12:09:38 PM
Author Topic:  Tires  (Read 376 times)
Offline Motohead
  • Jr. Member
  • -Given: 2
  • -Received: 0
  • Liked:
  • Likes Given: 0
Tires
« on: August 24, 2020, 12:24:58 PM »
So its time for some new shoes for my 2016 flex EB its run hard on the street and at the track. With the tune I have its spinning on the line (and closing the throttle blades) the factory tire size is 255/45R20 I'm looking for some recommendations for a good performance tire with more grip. and can I get a wider tire to fit without any issues. currently it has worn out  Lexani LX-twenty's tread wear 320 Traction A temp A
What are you  tuned guys running ?
2012 EB limited CAI,CATLESS DOWNPIPES,LMS 93++ tune
13.4 @101 150,000 miles and goin strong
2016 EB limited CAI,CATLESS DOWNPIPES,LMS 93++ tune
13s @85,000 miles and goin strong
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1050
  • -Received: 1220
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 21
Re: Tires
« Reply #1 on: August 24, 2020, 01:54:38 PM »
Quite a few SHO's on here are running the Continental Extreme Contact DWS06.  I love them, and they are a damn good all season tire.  I also went 1.77 to the sixty foot at the track with full stock suspension on the stock flower wheels with them.  26 psi in the front, 40 psi in the rear.  They work.
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | Stock IC with Ice Water DIY Sprayer | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
On deck: | ATP Turbos | Custom Air to Water IC, Heat Exchanger, and Ice Box |
Offline limited02
  • Full Member
  • Kansas
  • -Given: 64
  • -Received: 39
  • Hot Rod Lincoln
  • Liked:
  • Likes Given: 10
Re: Tires
« Reply #2 on: August 24, 2020, 10:24:22 PM »
I second the DWS06 tire!  I have them (255/45/20) and love them and believe you would too.  My second choice would be the General G-Max AS05.
Offline ridered74
  • RotM Winner
  • Full Member
  • -Given: 154
  • -Received: 253
    • Ken Kyle Racing
  • Liked:
  • Likes Given: 40
Re: Tires
« Reply #3 on: August 24, 2020, 11:37:28 PM »
My best 60' was 1.736 on Cooper Zeon RS3 all seasons at 35psi all the way around. Got 35K miles out of them and 150 or so passes down the track.
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
