Ecoboost Performance
Ecoboost Tuning!
Tuning and Devices
(Moderator:
Bench Tune Wiring
Bench Tune Wiring
Started by Gray Brick, December 31, 2018, 01:06:52 PM
Gray Brick
Sr. Member
Gray Brick
Bench Tune Wiring
I have been having trouble uploading my tunes using my X4. The last two uploads locked my PCM and it needed to be sent into SCT.
So....
They recommended that I run a bench tune setup. (example here:
https://www.youtube.com/watch?v=go6AksH45II
Does anyone have the wiring diagram for the OBD-II port to go directly to the PCM?
Thank you in advance.
2013 Ecoboost Ford Flex
Davidsiebert2
Jr. Member
Ecobooster
Re: Bench Tune Wiring
September 06, 2020, 10:41:47 PM
Have you gotten anywhere on this ?
Ecoboost Tuning!
Tuning and Devices
(Moderator:
Bench Tune Wiring
