Attached images of engine hot pipes and meth line. Brass nozzle is underneath facing upward. No boost reference adapter... Tapped into 3bar. According to the alky system leds meth is on and at pressure through duration of the entire pull... I have the settings on alky controls system set slightly more aggressively than Julio suggest. Just in an attempt to see if it helped. 10 o'clock "turn on", 2 o'clock "initial", 7 control box.
