October 28, 2020, 10:45:16 AM
Author Topic:  What would mildly shot sway bar bushings sound like?  (Read 359 times)
Offline TopherSho
  • Elite Member
  • Eugene Oregon
  • Thank You
  • -Given: 491
  • -Received: 385
  • 1st boosted rig!
  • Liked:
  • Likes Given: 0
« on: September 14, 2020, 11:32:55 PM »
Under low speed no load,  if I hit a small bump like less than a inch deep i get a super mild thunk/clunk .. I am **just** getting the noise,  no steering feedback nor do i feel it in my feet.
I can hit the same bumps in neutral and still hear it as well at the same 'volume'.
I think it is the 10 year old rubber in the bushings for the sway bar,  but not ruling out shocks and looking for opinions.  I am unable to record the noise as my old cellphone i used as a gopro crapped the bed finally .
If you listen to this video it is the same sound,  only mine is *WAY* more muted and does not occur under 'load' or higher speeds.  I'm driving about 10mph to hear it..
If i am driving under load,  i do not hear the noise .. even 10% throttle will prevent it as long as the car is getting pulled forward.
Turning for straight makes no diff...
2010 non-pp, 50k miles, 3-bar,  .30 plugs, 170-T-stat, SNOW-KIT STG1, AJP TURBO METH TUNE-REV3
Best of 12.61 no DA correction
Offline Dannymack
  • RotM Winner
  • Full Member
  • Longmont, CO
  • Thank You
  • -Given: 46
  • -Received: 95
  • Mile High Club
  • Liked:
  • Likes Given: 0
Re: What would mildly shot sway bar bushings sound like?
« Reply #1 on: September 14, 2020, 11:50:07 PM »
I had that in mine and most of the noise was the sway bar links. I do still have it a bit after replacing them, but a lot less than before. Still need to do the bushings to see if it goes away fully.
2013 MKS EcoBoost Fully Loaded
AJP E40 Tuned
XDI-35
Godspeed Springs
EBC Yellow Brake Pads
Offline TopherSho
  • Elite Member
  • Eugene Oregon
  • Thank You
  • -Given: 491
  • -Received: 385
  • 1st boosted rig!
  • Liked:
  • Likes Given: 0
« Reply #2 on: September 15, 2020, 12:09:01 AM »
Thank you for the feedback
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1942
  • -Received: 4084
  • Liked:
  • Likes Given: 0
« Reply #3 on: September 15, 2020, 07:21:12 AM »
I would try to rule out the (Strut assembly) Strut Mounts especially if original IMO! Z
https://www.rockauto.com/en/catalog/ford,2011,taurus,3.5l+v6+turbocharged,1446498,suspension,strut+mount,7600
Good thread below . Best of luck.
https://www.ecoboostperformanceforum.com/index.php/topic,7087.0.html
« Last Edit: September 15, 2020, 07:30:19 AM by ZSHO »
Offline TopherSho
  • Elite Member
  • Eugene Oregon
  • Thank You
  • -Given: 491
  • -Received: 385
  • 1st boosted rig!
  • Liked:
  • Likes Given: 0
« Reply #4 on: September 15, 2020, 11:50:33 AM »
updated testing,
rolling fwd in neutral yanking left to right - no noise
rolling fwd in idle yanking left to right - no noise
in park yanking left to right - no noise
in neutral with ebrake yanking left to right - no noise
seems limited to vertical motion .. this is promising .. bushing in my head or possible strut.  will take to my fav mechanic in a few days
« Last Edit: September 15, 2020, 12:05:33 PM by TopherSho »
Offline ridered74
  • RotM Winner
  • Full Member
  • Thank You
  • -Given: 153
  • -Received: 240
    • Ken Kyle Racing
  • Liked:
  • Likes Given: 31
« Reply #5 on: September 16, 2020, 12:19:26 AM »
Mine did it since I bought the car with 32K miles. Did the end links first since they looked worn out and seemed easier to replace, still had the noise. Replaced entire strut on both sides including strut mounts and she's been quiet ever since. Mine pretty much only made the noise going over speed bumps but it made the noise every single time I went over one.
Firestorm hpfp, catted downpipes, Corsa catback, 160 degree thermostat, 3 bar map, Gearhead E30 tune, Gearhead intercooler, upgraded trans mounts and EPP intake.
12.2479 @ 118.05 fastest trap
11.7513 @ 117.04   fastest ET
Offline TopherSho
  • Elite Member
  • Eugene Oregon
  • Thank You
  • -Given: 491
  • -Received: 385
  • 1st boosted rig!
  • Liked:
  • Likes Given: 0
« Reply #6 on: September 16, 2020, 09:31:06 AM »
TY,  starting to sounds more like strut bushings like Zsho and you mentioned ... okedoky.
Offline 6500rpm
  • Quality Always Shoots Straight
  • Full Member
  • the safe zone just outside St Louis
  • Thank You
  • -Given: 51
  • -Received: 110
  • Ecobooster
  • Liked:
  • Likes Given: 4
« Reply #7 on: September 16, 2020, 08:01:00 PM »
Take the links off and go for a ride and see if it stops. Worse case scenario, it still makes noise and it's one less thing to remove when you replace the struts (  ;
They can't be very expensive, if you end up replacing struts I'd do the links too, it's actually a fairly common failure.
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes,3 bar, Gearhead AO tuned!
Official Forum Sponsor of Ecoboost Performance Forum
