Ride of The Month - AUGUST 2020!!
Started by SM105K, August 03, 2020, 01:17:23 PM
StealBlueSho
4sfed
2015 SHO, GH E30 tune, GH intercooler, 3 bar, SP542's, PPE Cat'd DP's, XDI-35, H&R springs, AD Gen2 mounts
Factory Five Mark III, 2004 Mach I donor (gone)
2003 Mustang Cobra 'vert, 456 rwhp, with mods (gone)
2002 MB C32 AMG (gone)
1997 Cobra 'vert, Vortech'd (gone)
@StealBlueSHO.... (which, I will continue to keep pointing out, should really be "BJSHO" as you own, and have owned for quite some time, a Blue Jean's colored SHO) but I digress.
However, may I make a suggestion that I recall another Taurus community I used to be a part of years ago did.....
Please consider making an award for those that win ROTM each month.
Can be something simple. Even a mere .pdf file that can be emailed to the recipient, so that they can print it out on their end, and then in turn frame, and show case their achievement at local car shows and other events of such.
Make it a standard 8.5"x11". Have the EBPF logo on it. The applicable month/year. The recipient's forum user name (or actual name) or even both. Perhaps a pic of the recipient's winning photo.
I mean you get the idea, right?
Just a thought before you get to deep into winners as this was just started back up.
Would make it a win win for all involved and could create more traffic/hits for the community as well, when the intended viewers see the award and go "oh cool, there's an EcoBoost Performance community. Hey I got an EB. I should check it and join".
SM105K
Since this is detracting from ROTM I am going to make a new thread about the my trails and tribulations with this spoiler.
StealBlueSho
Quote from: bpd1151 on August 12, 2020, 11:24:50 AM
I really like this idea as per our phone convo. I will start looking into this! I am always up for good suggestions. Give me some time work this out!
SM105K
Get your pictures and votes in for ROTM.  I will be forgoing this month because there is still a couple of things to shore up on my SHO before I submit.  Good luck to everyone this month!
StealBlueSho
Last few hours to vote!!! Get it done!!!
ridered74
Or maybe a small sticker....local track has stickers for perfect light club, maybe something similar to that?
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
StealBlueSho
#23
Congrats @Macgyver for winning the August RoTM!!!
Quote from: StealBlueSHO on September 01, 2020, 09:51:28 AM
Woo Hoo! Well done, well done!
Insert **applause here**
802SHO
Congrats!!
SM105K
