Carbon hood install
Started by GotGrip?, July 23, 2020, 01:10:06 AM
GotGrip?
If you aren't handy with a dremel or lite DIY then maybe this is not for you.
Ok let's start off by saying the packaging and quality were pretty top notch. I will admit that my hood came with some slight damage but nothing that would be a deal breaker for even an average person. That out of the way, time to dig in!
First off, before you take off your hood, go to a hardware store and pick up a couple things. The hinge and striker bolts from your stock hood WILL NOT WORK! The bolts that come with the hood will not work because the hinge bolts are too long and the striker bolts are too short to be safe in my opinion. You will need 4 M8 x 1.25 pitch for the hinges and 2 M6x1.00 pitch for the striker. I bought additional washers to be safe. Make sure to drive down the bolts BY HAND before putting the hood up on the car. This will give you a chance to clean out resin and debris before you're stuck in an awkward position over you car with a hood on your head doing a circus balancing act while trying to thread the bolts... Or so I hear... Once all that is done put the the hood up and bolt it down BY HAND so not to wreck mounting area. Then close up the hood and you're done!
Or at least that is what would like to say but you would be wrong! So after the hood is attached, you remember that striker you put on? Look at it again! You'll notice there is not a hole in the hood for the hood latch to go into so your hood won't close. Put some grease/toothpaste on the latch and drop the hood down to mark where to cut. Now cut a 1"x 2" hole in the underside of the hood to fit said latch. I used a 90 degree electric saw, a dremel will work or any type of cutting tool. Now drop the hood and you're ready to roll!
Just kidding! You will now notice that the hood sits a little low and you'll start you realize that none of the trim on your hood can transfer. But, you will need to get the rubber bumpers! From there I could only think of 3 options, leave it, but the hood would be loose and rattle/shake, which is not adviseable. Cut up/drill the hood to add hood pins. And the last, fit the bumpers from the stock hood on to the body some where or use metal/pad screw type hood cushions on GM trucks. The hood bumpers would be incredibly hard to mount on the hood itself due to the thickness of material on the lower. I chose the latter, but will be tapping for truck style bumpers tomorrow when I get the parts.
I do have aerotech hood pins I could install I just really don't want to ruin the clean look and it hurts my soul lol.
With the current use of stock bumpers they are basically maxed out to use this method so the hood has probably the minimum comfort level to feel safe to drive. The hood sits fairly flush with these but if your fenders have ever been removed and reglued/spot welded on they may not fit as good or they may even fit better, hard to say.
So overall, easy install and I got to spend some time with my dad and my daughter got to help so that was cool. This shouldn't take more than 30 mins to install assuming you did all the prior item purchases and prep the area.
Stock Hood Weighed in a little over 45 lbs, this hood weighed in at just under 30 lbs, so its around a 15 lbs drop.
Edit: Just to clarify, when I said by hand, I meant with hand tools, not mini impacts, too much vibration could break something.
2016 SHO Non-PP, GH/AJP E30 Tune,3Bar MAP, K&N Typoon, EPP Noisemaker Delete, H&R Springs, ZEDD SL5 19x9.5, PS Drilled/Slotted rotors, TreadStone TR8C FMIC, SSM Trans Mounts, TCE Custom Catted DPs, FMIC Sprayer, XDI35
Bronco2fan
Very clean install and looks killer. Carbon fiber really dazzles in the sunlight.  Just a little info from my experience with carbon fiber hoods. I hope you took it and had someone add more clearcoat to it or at the very least prep and ceramic coat it. Mine on my SN95 GT lasted about 2 years before I noticed the clearcoat and gelcoat breaking down (Daily driver). Bought it from a reputable supplier too.
2019 Mustang GT, Velocity Blue 5.0 PP, 2015 Audi Q7 TFSI Quattro. 2013 Ruby Red Metallic, PP.  06 F150 Harley-Davidson Edition, 03 Mustang GT Conv, 84 Bronco II, and my 97 Jeep GC Laredo 5.2.
GotGrip?
I polish and coated it after I put it on the car to try and mitigate yellowing. I'm pretty good about washing my car and using ceramic spray, i probably wash it once a week.
xartic1
Quote from: Bronco2fan on July 23, 2020, 11:13:33 AM
I can agree with this as I have issues with my 2011 Mustang's CF hood. Garage kept and still developed cracks, even in a heated garage. I didn't drive it for a year to rebuild the driveline and it still managed to get more cracks. Currently looking for someone to do the repairs on it.
GotGrip, did you install a hood liner on it? I wonder if the heat and stress from my suspension is what caused my to crack. What's strange about it is the sides and front near the fender and bumper only cracked not the main part of it where most the heat comes from my motor. It's a GT500 style hood.
Anyway, that hood looks very clean on your car and will get you plenty of compliments.
2014 Explorer Sport - Livernois 91 tune, 3 Bar MAP, Bilstein B6's, Dicunzolo Transmission Mounts, Mishimoto J-Line FMIC, AEM Drop In Filter, Steeda Rear Sway Bar, PPE Engineering Catless Downpipes, Reische 170 T-stat
2011 Mustang GT Brembo - Bama 91 tune, Steeda Intake,  LTH, 3" full exhaust with O/R X-Pipe no resonator, every possible suspension component replaced, weighs 3505 with 1/4 gas
GotGrip?
The only thing I could transfer was the striker and the rubber bumpers (sort of). There is a front seal I want to transfer but I'll need to drill some holes for the clips. I don't know if it will even stay if the clips can't set due to the material thickness so that might be out.
802SHO
I really like it
4sfed
Dude....sweet!  Looks sharp.
2015 SHO, GH E30 tune, GH intercooler, 3 bar, SP542's, PPE Cat'd DP's, XDI-35, H&R springs, AD Gen2 mounts
Factory Five Mark III, 2004 Mach I donor (gone)
2003 Mustang Cobra 'vert, 456 rwhp, with mods (gone)
2002 MB C32 AMG (gone)
1997 Cobra 'vert, Vortech'd (gone)
SHO NVS
2013 SHO PP, 3BAR MAP, Gearhead Tune, EPP CAI, 170* Thermo, JLT Catch Can, MSD Coils, H&R Springs, Magnaflow Cat Back Exhaust, PPE Catted Downpipes, Whiteline Rear Sway Bar, SSM Motor Mounts, Gearhead Intercooler, Gearhead Upgraded Turbos, Noise Maker Delete, Boomba Racing BOV
