Ecoboost Performance
General Discussion
remove then add fluid without having to bleed?
Started by TopherSho, July 28, 2020, 04:59:56 PM
TopherSho
1st boosted rig!
Per the title, i have not added in any water wetter after the rebuild, but need to and do not want to bleed the damn thing for the next 4 weeks... is there any way to remove about 2 qts fluid and add in 2 qts of water wetter for the head temps ?
2010 non-pp, 98k miles, 3-bar, .026 plugs, SNOW-KIT STG1, AJPTurbu tune#35, 15.5+psi
Best 0-60 public road 4.35s
Black Dream
Ecocrazy
Forum Supporters
Full Member
Ecobooster
Re: remove then add fluid without having to bleed?
August 03, 2020, 08:20:50 PM
Wouldn't it be simple to drain 2 qts, out and then use a Lisle funnel to replace the drained fluid? I did a coolant flush on the MKS 2 months ago with a Lisle and didn't have to bleed the system a bit. I did have to add about 8 oz. of fluid after I ran the car a couple of times. In the scorching South Texas summer haven't had an issue with overheating since.
2010 MKS Eco, Airaid, SCT X4, Unleashed, SP542 plugs, 3 bar MAP and current daily.
2006 Pontiac GTO M6, 1 of 101 exactly like her, bone stock, lost to flood 5/19, gone but not forgotten....
nickstewartroc
Sr. Member
Ecobooster
August 03, 2020, 10:20:07 PM
You can also look into vacuum refiller systems. I bought this one last week
https://www.amazon.com/gp/product/B01BW39HJS
and it worked great
Current:
2013 Ruby Red Flex Limited EcoBoost, Unleashed Tuned, drop in filter
Gone but not forgotten: 2011 SHO Non-PP in Black Tuxedo Metallic - Catback, DPs, Stoptech Z23s, MDesign CAI, LMS Tune
General Discussion
