September 24, 2023, 09:59:40 PM
Author Topic:  HOW-TO: 3.5L EcoBoost AD Transmission Mounts  (Read 5108 times)
Offline Ecoboost_xsport
  • 2015 Ford Explorer Sport
  • Full Member
  • Orangevale, CA
  • -Given: 85
  • -Received: 138
  • Mad Scientist
    • For The Workshop
  • Liked:
  • Likes Given: 9
« on: July 12, 2020, 09:29:28 PM »
Wanted to just make a quick (aka, LONG) video of the install process.  Going on an Explorer but the process is the same for the SHO.  It's really very easy and straight forward.  Even with all the unedited parts where I'm away from the cam, the video was still only 30 minutes, so install time on these is actually even less. Oh, and please disregard the wooden block.  I thought, for some reason, the trans would drop a bit and was just playing it safe with some blocking.  Anyway, turned out it doesn't budge and I didn't need it...
Those of you looking to scoop up a set of these may find it difficult to locate.  Well, he only sells them direct and doesn't have much of an online presence.  You either have to contact him via email: tonyuep@aol.com or through his Instagram page Anthony DiCunzolo.
Before:
After:
Front mount comparison:
Rear mount comparison:
« Last Edit: December 18, 2020, 10:24:46 PM by Ecoboost_xsport »
Offline Macgyver
  • Super Moderator
  • Eastern Pa.......
  • -Given: 100
  • -Received: 396
  • 2020 Red ST
  • Liked:
  • Likes Given: 37
Re: HOW-TO: AD Trans Mounts
« Reply #1 on: July 12, 2020, 09:53:42 PM »
Thank you for the video !!! It is always nice to see the face behind the name.
Offline ThePresidential
  • Jr. Member
  • Huntley, IL
  • -Given: 3
  • -Received: 1
  • Liked:
  • Likes Given: 2
Re: HOW-TO: 3.5L EcoBoost AD Transmission Mounts
« Reply #2 on: August 18, 2022, 03:39:49 AM »
Im ordering this set soon, should you also replace the engine mount and the other trans mount as well?
2013 Lincoln MKS Ecoboost | Oil breather | spectre CAI | Needing to install catch cans | 160 thermostat |
Offline Macgyver
  • Super Moderator
  • Eastern Pa.......
  • -Given: 100
  • -Received: 396
  • 2020 Red ST
  • Liked:
  • Likes Given: 37
« Reply #3 on: August 18, 2022, 12:02:06 PM »
They all can help but will just add more interior cabin noise. They do make the car sound more like a race car than the exhaust does. (on the inside)
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • -Given: 19
  • -Received: 275
  • Bewsted SHO
    • Ortiz Tuning and Performance
  • Liked:
  • Likes Given: 10
« Reply #4 on: September 07, 2022, 12:50:25 PM »
Depending on your vehicle mileage, I would definitely recommend it. Poor rubber choice without vulcanization leads the stock mounts to an early grave, most rarely make it past 60k miles. If you have access to a snake camera (they offer them for your cell phone on Amazon for under $20) you can inspect them without tearing down the top end of the engine and tell if they need to be replaced.
Also, if you put the car in neutral on LEVEL ground, pull the car back slightly then push hard away from you, you can listen for any pops or clunks and see if the engine rocks, which is an indicator that a mount is shot and needs to be replaced.
« Last Edit: September 07, 2022, 12:52:37 PM by FiveLeeter918 »
- Lee
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • -Given: 19
  • -Received: 275
  • Bewsted SHO
  • Liked:
  • Likes Given: 10
« Reply #5 on: September 07, 2022, 12:51:47 PM »
You can also ask your tuner to increase your idle speed by 100 rpm which will get rid of a lot of the NVH.
- Lee
  • Jr. Member
  • Huntley, IL
  • -Given: 3
  • -Received: 1
  • Liked:
  • Likes Given: 2
« Reply #6 on: November 14, 2022, 01:54:56 PM »
When i tighten my lug nuts the car rocks back and forth a bit, is this a sign of bad engine and or trans mounts?
* Recent Topics
Re: My Staggered, TSW Wheel Setup.....
by dillrepair | September 23, 2023, 08:51:58 PM
Just wanted to say thanks to bpdHave the same setup bc of seeing this ...
Re: Body kits
by MKSJUNKIE | September 12, 2023, 10:23:45 PM
Sounds good I appreciate it. I...
Re: PTU Upgrade - Dorman
by BlueSHO | September 11, 2023, 10:46:17 AM
@timbo anything?Sent from my SM-G781V using Tapatalk...
Re: 2012 SHO PP
by bpd1151 | September 01, 2023, 08:25:20 PM
Pics are always helpful..... I mean c'mon now..... who doesn'...
Re: Fuel injector coding
by SHOdded | August 15, 2023, 01:38:53 PM
i would say to try new injectors then since fuel pump operation is goo...
Re: 315s?
by fsttyms1 | August 04, 2023, 03:40:50 PM
Thanks for the input guys. I did some reading around and even though b...
by kryptto | August 02, 2023, 09:12:14 PM
Just a quick update.....Went and visited the shop yesterday (07/21/202...
LH (Driver Side) Halfshaft Removal Tips?
by DaveBey | July 29, 2023, 09:54:27 PM
Does anyone have any tips for removing the LH (driver side) halfshaft?...
Re: New block, low oil pressure
by SHOdded | July 26, 2023, 01:56:20 PM
do you have an sho block or one from an explorer? their setups are sli...
Re: MSD Coils on 75% Sale
by SHOdded | July 26, 2023, 10:41:09 AM
feels like a closeout ... once gone, gone....
